Salta al contenuto principale
Hot Tools Professional 1110 Power Switch Replacement
Cosa ti serve
  1. Hot Tools Professional 1110 Power Switch Replacement, Hot Tools Professional 1110 Disassembly: passo 1, immagine 1 di 1
    • Ensure that you have a clean work station, and that you can easily keep track of small, loose parts.
    • In addition, MAKE SURE IT IS UNPLUGGED FOR ALL FOLLOWING STEPS!
  2. Hot Tools Professional 1110 Power Switch Replacement: passo 2, immagine 1 di 2 Hot Tools Professional 1110 Power Switch Replacement: passo 2, immagine 2 di 2
    • Firmly grasp the end of the Iron with the black plastic cap on the heating element end.
    • With your free hand, use tweezers to firmly grasp the small retaining ring sitting between the heating element and the handle body.
    • Once you have a firm grasp, pull up on the retaining ring, and it should come loose.
  3. Hot Tools Professional 1110 Power Switch Replacement: passo 3, immagine 1 di 1
    • With the ring loose, turn the handle body over, and you will see three screw holes.
    • Take a PH1 screwdriver, and loosen up all three 6mm Phillips #1 screws in the handle body.
  4. Hot Tools Professional 1110 Power Switch Replacement: passo 4, immagine 1 di 1
    • Once the screws have been removed, set them aside and with a pry tool, firmly pull the handle body apart in half lengthwise.
  5. Hot Tools Professional 1110 Power Switch Replacement: passo 5, immagine 1 di 2 Hot Tools Professional 1110 Power Switch Replacement: passo 5, immagine 2 di 2
    • For removing the clamping mechanism, firmly grasp the iron in your hand by the handle body, and locate the screw as shown in the picture.
    • Remove the screw shown (8mm Phillips #2 Pan Head) and when finished do the same for the opposite side.
  6. Hot Tools Professional 1110 Power Switch Replacement: passo 6, immagine 1 di 1
    • Once both screws have been removed, continue to remove the top clamping half of the mechanism from the body of the Iron.
  7. Hot Tools Professional 1110 Power Switch Replacement: passo 7, immagine 1 di 1
    • Rotate the handle, and remove the screw that holds on the spring mechanism for the clamp. This screw is a 8mm Phillips #2 Pan Head.
    • Once this step is fished your Hot Tools Professional 1110 will be fully disassembled and ready to have its components replaced.
  8. Hot Tools Professional 1110 Power Switch Replacement, Power Switch: passo 8, immagine 1 di 2 Hot Tools Professional 1110 Power Switch Replacement, Power Switch: passo 8, immagine 2 di 2
    • Remove the power switch button exposing the electrically connected power switch.
  9. Hot Tools Professional 1110 Power Switch Replacement: passo 9, immagine 1 di 1
    • Remove power switch from the housing and desolder the three connected electrical wires. Take note of the orientation of each of the electrical wires to ensure that they are replaced correctly.
  10. Hot Tools Professional 1110 Power Switch Replacement: passo 10, immagine 1 di 1
    • Ensuring that the three connecting electrical wires are in the correct orientation, solder the new power switch to the wires.
Conclusione
IUPUI, Team S2-G2, Wilson Fall 2017 Membro di IUPUI, Team S2-G2, Wilson Fall 2017
IUPUI-WILSON-F17S2G2
4 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 7
Tutti i Tempi: 199
