Salta al contenuto principale
Hot Tools Professional 1110 Disassembly
Cosa ti serve
  1. Hot Tools Professional 1110 Disassembly, Hot Tools Professional 1110 Disassembly: passo 1, immagine 1 di 1
    • Ensure that you have a clean work station, and that you can easily keep track of small, loose parts.
    • In addition, MAKE SURE IT IS UNPLUGGED FOR ALL FOLLOWING STEPS!
  2. Hot Tools Professional 1110 Disassembly: passo 2, immagine 1 di 2 Hot Tools Professional 1110 Disassembly: passo 2, immagine 2 di 2
    • Firmly grasp the end of the Iron with the black plastic cap on the heating element end.
    • With your free hand, use tweezers to firmly grasp the small retaining ring sitting between the heating element and the handle body.
    • Once you have a firm grasp, pull up on the retaining ring, and it should come loose.
  3. Hot Tools Professional 1110 Disassembly: passo 3, immagine 1 di 1
    • With the ring loose, turn the handle body over, and you will see three screw holes.
    • Take a PH1 screwdriver, and loosen up all three 6mm Phillips #1 screws in the handle body.
  4. Hot Tools Professional 1110 Disassembly: passo 4, immagine 1 di 1
    • Once the screws have been removed, set them aside and with a pry tool, firmly pull the handle body apart in half lengthwise.
  5. Hot Tools Professional 1110 Disassembly: passo 5, immagine 1 di 2 Hot Tools Professional 1110 Disassembly: passo 5, immagine 2 di 2
    • For removing the clamping mechanism, firmly grasp the iron in your hand by the handle body, and locate the screw as shown in the picture.
    • Remove the screw shown (8mm Phillips #2 Pan Head) and when finished do the same for the opposite side.
  6. Hot Tools Professional 1110 Disassembly: passo 6, immagine 1 di 1
    • Once both screws have been removed, continue to remove the top clamping half of the mechanism from the body of the Iron.
  7. Hot Tools Professional 1110 Disassembly: passo 7, immagine 1 di 1
    • Rotate the handle, and remove the screw that holds on the spring mechanism for the clamp. This screw is a 8mm Phillips #2 Pan Head.
    • Once this step is fished your Hot Tools Professional 1110 will be fully disassembled and ready to have its components replaced.
Conclusione
Sean Neal
Membro da: 11/11/17
101 Reputazione
1 Guida realizzata
IUPUI, Team S2-G2, Wilson Fall 2017 Membro di IUPUI, Team S2-G2, Wilson Fall 2017
IUPUI-WILSON-F17S2G2
4 Membri
5 Guide realizzate
2 Commenti
How can I tighten the clamp?
Sharon Gonzalez - Replica
where can i get or order the part for the (spring with small roller)
i have a model ht1110xl hot tools iron
Fred Medina - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 47
Tutti i Tempi: 3,660
