Salta al contenuto principale
Hori Real Arcade Pro N Push Button Replacement
Cosa ti serve
  1. Hori Real Arcade Pro N Push Button Replacement, Push Button: passo 1, immagine 1 di 2 Hori Real Arcade Pro N Push Button Replacement, Push Button: passo 1, immagine 2 di 2
    • Flip your Fight Stick so the bottom is facing up.
    • Remove the sticker covering the screw in the bottom middle of the device.
    • Remove eight screws from the bottom of the device using a Phillips #0 screwdriver.
  2. Hori Real Arcade Pro N Push Button Replacement: passo 2, immagine 1 di 2 Hori Real Arcade Pro N Push Button Replacement: passo 2, immagine 2 di 2
    • Find the storage compartment that holds the USB wire.
    • Open the case by putting your hand in the compartment and pushing up.
    • Put your Fight Stick on its side to make the other steps easier.
  3. Hori Real Arcade Pro N Push Button Replacement: passo 3, immagine 1 di 2 Hori Real Arcade Pro N Push Button Replacement: passo 3, immagine 2 di 2
    • Use your fingers to pull the black grip to detach both wires connected to the pushbutton.
    • Pulling the wire instead of the black grip can cause the wires to not function.
  4. Hori Real Arcade Pro N Push Button Replacement: passo 4, immagine 1 di 2 Hori Real Arcade Pro N Push Button Replacement: passo 4, immagine 2 di 2
    • Twist the button you are planning to remove.
    • The tabs must be on its side as shown in the second picture so it is easier to grab in the next step.
  5. Hori Real Arcade Pro N Push Button Replacement: passo 5, immagine 1 di 3 Hori Real Arcade Pro N Push Button Replacement: passo 5, immagine 2 di 3 Hori Real Arcade Pro N Push Button Replacement: passo 5, immagine 3 di 3
    • Squeeze the tabs in the button.
    • While squeezing, push the button inward, so it falls out.
Conclusione
gabriel garcia
Membro da: 01/24/22
121 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 15
Ultimi 30 Giorni: 64
Tutti i Tempi: 1,619
