Salta al contenuto principale
Hoover Windtunnel Air Steerable Upright Wheel Replacement
Cosa ti serve
  1. Hoover Windtunnel Air Steerable Upright Wheel Replacement, Wheel: passo 1, immagine 1 di 1
    • Lay the vacuum flat on the ground, then flip it over 180 degrees so that you can see the inside of the wheel.
  2. Hoover Windtunnel Air Steerable Upright Wheel Replacement: passo 2, immagine 1 di 2 Hoover Windtunnel Air Steerable Upright Wheel Replacement: passo 2, immagine 2 di 2
    • Locate the small metal pin and bolt holding the wheel in place.
  3. Hoover Windtunnel Air Steerable Upright Wheel Replacement: passo 3, immagine 1 di 1
    • Take the needle nose pliers and stick them in the rectangular hole.
    • With the pliers, firmly grasp the metal pin that holds the bolt for the wheel in place.
    • Slide the pin off the bolt by pushing the pliers forward.
    • Carefully remove the pin from the rectangular hole and keep it in a safe place.
  4. Hoover Windtunnel Air Steerable Upright Wheel Replacement: passo 4, immagine 1 di 1
    • Now, remove the wheel by pulling it away from the vacuum.
    • The bolt will come out with the wheel since the pin is gone.
Linea Traguardo
Cal Poly, Team S7-G2, Banghart Fall 2017 Membro di Cal Poly, Team S7-G2, Banghart Fall 2017
CPSU-BANGHART-F17S7G2
5 Membri
14 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 20
Tutti i Tempi: 3,695
