Salta al contenuto principale
Hoover Windtunnel Air Steerable Upright Rinsable and HEPA Filter Replacement
  1. Hoover Windtunnel Air Steerable Upright Rinsable and HEPA Filter Replacement, Rinsable Filter: passo 1, immagine 1 di 1
    • Put the cleaner into the upright position, turn off the power and unplug the power cord.
  2. Hoover Windtunnel Air Steerable Upright Rinsable and HEPA Filter Replacement: passo 2, immagine 1 di 3 Hoover Windtunnel Air Steerable Upright Rinsable and HEPA Filter Replacement: passo 2, immagine 2 di 3 Hoover Windtunnel Air Steerable Upright Rinsable and HEPA Filter Replacement: passo 2, immagine 3 di 3
    • Remove the dirt cup from the cleaner.
    • Twist the top of the dirt cup to open it and reveal the rinsable filter.
  3. Hoover Windtunnel Air Steerable Upright Rinsable and HEPA Filter Replacement: passo 3, immagine 1 di 3 Hoover Windtunnel Air Steerable Upright Rinsable and HEPA Filter Replacement: passo 3, immagine 2 di 3 Hoover Windtunnel Air Steerable Upright Rinsable and HEPA Filter Replacement: passo 3, immagine 3 di 3
    • Remove the rinsable filter from the dirt cup.
    • If the rinsable filter is dirty, rinse it with water for 2 minutes or until the water runs clear.
    • Squeeze out excess water and allow to dry for 24 hours.
    • Never put a wet filter back into the cleaner.
Linea Traguardo
Cal Poly, Team S7-G2, Banghart Fall 2017 Membro di Cal Poly, Team S7-G2, Banghart Fall 2017
CPSU-BANGHART-F17S7G2
5 Membri
14 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 10
Tutti i Tempi: 646
