Salta al contenuto principale
Hoover Windtunnel Air Steerable Upright Motor Assembly Replacement
Cosa ti serve
  1. Hoover Windtunnel Air Steerable Upright Motor Assembly  Replacement, HEPA Filter: passo 1, immagine 1 di 2 Hoover Windtunnel Air Steerable Upright Motor Assembly  Replacement, HEPA Filter: passo 1, immagine 2 di 2
    • Put the cleaner into the upright position, turn the power off, and unplug the power cord.
  2. Hoover Windtunnel Air Steerable Upright Motor Assembly  Replacement: passo 2, immagine 1 di 3 Hoover Windtunnel Air Steerable Upright Motor Assembly  Replacement: passo 2, immagine 2 di 3 Hoover Windtunnel Air Steerable Upright Motor Assembly  Replacement: passo 2, immagine 3 di 3
    • Remove the dirt cup from the cleaner.
    • The HEPA filter is located under the dirt cup and under where it says HEPA.
    • Twist the top counterclockwise to unlock the cap.
  3. Hoover Windtunnel Air Steerable Upright Motor Assembly  Replacement: passo 3, immagine 1 di 2 Hoover Windtunnel Air Steerable Upright Motor Assembly  Replacement: passo 3, immagine 2 di 2
    • Lift the HEPA filter out.
    • Tap the filter against the inside of a trashcan to knock out the dirt and debris or replace as necessary.
    • Do not wash the HEPA Filter.
  4. Hoover Windtunnel Air Steerable Upright Motor Assembly  Replacement, Motor Assembly: passo 4, immagine 1 di 3 Hoover Windtunnel Air Steerable Upright Motor Assembly  Replacement, Motor Assembly: passo 4, immagine 2 di 3 Hoover Windtunnel Air Steerable Upright Motor Assembly  Replacement, Motor Assembly: passo 4, immagine 3 di 3
    • Remove the 4 retaining screws and remove the filter tray.
    • Screw lengths are approximately 3/4".
  5. Hoover Windtunnel Air Steerable Upright Motor Assembly  Replacement: passo 5, immagine 1 di 1
    • Pull the motor housing vertically to dislodge the motor.
  6. Hoover Windtunnel Air Steerable Upright Motor Assembly  Replacement: passo 6, immagine 1 di 3 Hoover Windtunnel Air Steerable Upright Motor Assembly  Replacement: passo 6, immagine 2 di 3 Hoover Windtunnel Air Steerable Upright Motor Assembly  Replacement: passo 6, immagine 3 di 3
    • Use a plastic spudger or opening tool to press on the small circle and wiggle clips free.
Conclusione
Altre 2 persone hanno completato questa guida.
steven hoover
Membro da: 09/26/17
257 Reputazione
2 Guide realizzate
Cal Poly, Team S7-G2, Banghart Fall 2017 Membro di Cal Poly, Team S7-G2, Banghart Fall 2017
CPSU-BANGHART-F17S7G2
5 Membri
14 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 46
Tutti i Tempi: 3,952
