Salta al contenuto principale
Hoover WindTunnel 2 Rewind Primary Air Filter Replacement
Cosa ti serve
  1. Hoover WindTunnel 2 Rewind Primary Air Filter Replacement, Primary Air Filter: passo 1, immagine 1 di 1
    • Press button on the top of the dust cup and pull back.
    • Remove dust cup from vacuum
  2. Hoover WindTunnel 2 Rewind Primary Air Filter Replacement: passo 2, immagine 1 di 1
    • Pull back on black lever and rotate dust cup lid back.
  3. Hoover WindTunnel 2 Rewind Primary Air Filter Replacement: passo 3, immagine 1 di 1
    • Lift up on fabric flap to remove filter from vaccum
    • If you wish to clean the filter rather than replace it, it can be washed under a faucet.
    • If washing the filter, make sure it fully dries out before re-installing.
Conclusione
Cal Poly, Team S11-G4, Banghart Winter 2018 Membro di Cal Poly, Team S11-G4, Banghart Winter 2018
CPSU-BANGHART-W18S11G4
5 Membri
10 Guide realizzate
Un commento
Can I rinse it with warm water and soap? Or just warm water?
lacey sodapop - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 29
Tutti i Tempi: 2,419
