Salta al contenuto principale
Hoover WindTunnel 2 Rewind Dust Cup Assembly Replacement
Cosa ti serve
  1. Hoover WindTunnel 2 Rewind Dust Cup Assembly Replacement, Primary Air Filter: passo 1, immagine 1 di 1
    • Press button on the top of the dust cup and pull back.
    • Remove dust cup from vacuum
  2. Hoover WindTunnel 2 Rewind Dust Cup Assembly Replacement: passo 2, immagine 1 di 1
    • Pull back on black lever and rotate dust cup lid back.
  3. Hoover WindTunnel 2 Rewind Dust Cup Assembly Replacement: passo 3, immagine 1 di 1
    • Lift up on fabric flap to remove filter from vaccum
    • If you wish to clean the filter rather than replace it, it can be washed under a faucet.
    • If washing the filter, make sure it fully dries out before re-installing.
  4. Hoover WindTunnel 2 Rewind Dust Cup Assembly Replacement, Dust Cup Assembly: passo 4, immagine 1 di 1
    • Holding onto both the top handle and dust cup body, twist the two components apart following the instructions printed on the back.
  5. Hoover WindTunnel 2 Rewind Dust Cup Assembly Replacement: passo 5, immagine 1 di 2 Hoover WindTunnel 2 Rewind Dust Cup Assembly Replacement: passo 5, immagine 2 di 2
    • Unscrew the three 4 cm Phillips #3 screws located inside the dust filter compartment to detach the dust filter system.
Conclusione
Chino Cruz
Membro da: 01/22/18
135 Reputazione
1 Guida realizzata
Cal Poly, Team S11-G4, Banghart Winter 2018 Membro di Cal Poly, Team S11-G4, Banghart Winter 2018
CPSU-BANGHART-W18S11G4
5 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 13
Ultimi 30 Giorni: 46
Tutti i Tempi: 4,599
