Salta al contenuto principale
Hoover WindTunnel 2 Rewind Belt and Roller Brush Replacement
Cosa ti serve
  1. Hoover WindTunnel 2 Rewind Belt and Roller Brush  Replacement, Belt and Roller Brush: passo 1, immagine 1 di 2 Hoover WindTunnel 2 Rewind Belt and Roller Brush  Replacement, Belt and Roller Brush: passo 1, immagine 2 di 2
    • Remove the four 20 mm Phillips #1 head screws holding the top cover on.
    • Lift off the cover.
  2. Hoover WindTunnel 2 Rewind Belt and Roller Brush  Replacement: passo 2, immagine 1 di 1
    • Grab on both ends of the roller brush, lifting it and the attached belt clear of the housing.
  3. Hoover WindTunnel 2 Rewind Belt and Roller Brush  Replacement: passo 3, immagine 1 di 2 Hoover WindTunnel 2 Rewind Belt and Roller Brush  Replacement: passo 3, immagine 2 di 2
    • Reinstall belt and roller making sure that the white text is facing outwards on the belt.
    • Placing the roller brush in its guides will put some tension on the belt after the roller is in place spin it with your hand a couple times to ensure that it spins freely.
Conclusione
Altre 2 persone hanno completato questa guida.
Cal Poly, Team S11-G4, Banghart Winter 2018 Membro di Cal Poly, Team S11-G4, Banghart Winter 2018
CPSU-BANGHART-W18S11G4
5 Membri
10 Guide realizzate
Un commento
Thank you, made it easy peasy!
J Colee - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 5
Ultimi 7 Giorni: 22
Ultimi 30 Giorni: 112
Tutti i Tempi: 8,886
