Introduzione
This guide is intended to help you replace the brush roll on your vacuum. Please see the troubleshooting guide to determine if this needs replacement. Begin this step with the vacuum unplugged, and laying on the floor with the bottom facing towards you.
Strumenti
Parti
  1. Push the red release lever to the right. Turn the red switch counterclockwise. Tilt the bottom of the plastic tray out towards you and pull it off the vacuum.
    • Push the red release lever to the right.
    • Turn the red switch counterclockwise.
    • Tilt the bottom of the plastic tray out towards you and pull it off the vacuum.
  2. Spedizione gratuita per tutti gli ordini superiori a 100 US$ o contenenti un Kit Attrezzi Pro Tech!
    Sfoglia il Nostro Negozio
  3. Pull brush roll out of vacuum.
    • Pull brush roll out of vacuum.
    • Remove belt from brush roller
Conclusione
Cal Poly, Team S11-G2, Banghart Winter 2018 Membro di Cal Poly, Team S11-G2, Banghart Winter 2018
CPSU-BANGHART-W18S11G2
5 Membri
5 Guide realizzate
When you turn the vacuum on the brush roller works until you release the handle to start vacuuming then the brush roller stops. How do I correct this issue?
Brenda Brenda - Replica
Mine does the same thing. I have replaced the belt but that didn’t help
Ann - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 24
Tutti i Tempi: 197
