Salta al contenuto principale
Hoover T-Series WindTunnel Pet UH70102 Brush Roll Replacement
Cosa ti serve
  1. Hoover T-Series WindTunnel Pet UH70102 Brush Roll Replacement, Brush Roll: passo 1, immagine 1 di 3 Hoover T-Series WindTunnel Pet UH70102 Brush Roll Replacement, Brush Roll: passo 1, immagine 2 di 3 Hoover T-Series WindTunnel Pet UH70102 Brush Roll Replacement, Brush Roll: passo 1, immagine 3 di 3
    • Push the red release lever to the right.
    • Turn the red switch counterclockwise.
    • Tilt the bottom of the plastic tray out towards you and pull it off the vacuum.
  2. Hoover T-Series WindTunnel Pet UH70102 Brush Roll Replacement: passo 2, immagine 1 di 1
    • Pull the brush roll out of vacuum.
    • Remove the belt from brush roller
Conclusione
Cal Poly, Team S11-G2, Banghart Winter 2018 Membro di Cal Poly, Team S11-G2, Banghart Winter 2018
CPSU-BANGHART-W18S11G2
5 Membri
9 Guide realizzate
3 Commenti
When you turn the vacuum on the brush roller works until you release the handle to start vacuuming then the brush roller stops. How do I correct this issue?
Brenda Brenda - Replica
Did you ever get an answer on this issue or figure it out? I am having the same problem!
Val -
Mine does the same thing. I have replaced the belt but that didn’t help
Ann - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 14
Tutti i Tempi: 1,016
