Salta al contenuto principale
Hoover T-Series WindTunnel Pet UH70102 Belt Replacement
Cosa ti serve
  1. Hoover T-Series WindTunnel Pet UH70102 Belt Replacement, Brush Roll: passo 1, immagine 1 di 3 Hoover T-Series WindTunnel Pet UH70102 Belt Replacement, Brush Roll: passo 1, immagine 2 di 3 Hoover T-Series WindTunnel Pet UH70102 Belt Replacement, Brush Roll: passo 1, immagine 3 di 3
    • Push the red release lever to the right.
    • Turn the red switch counterclockwise.
    • Tilt the bottom of the plastic tray out towards you and pull it off the vacuum.
  2. Hoover T-Series WindTunnel Pet UH70102 Belt Replacement: passo 2, immagine 1 di 1
    • Pull the brush roll out of vacuum.
    • Remove the belt from brush roller
  3. Hoover T-Series WindTunnel Pet UH70102 Belt Replacement, Belt: passo 3, immagine 1 di 3 Hoover T-Series WindTunnel Pet UH70102 Belt Replacement, Belt: passo 3, immagine 2 di 3 Hoover T-Series WindTunnel Pet UH70102 Belt Replacement, Belt: passo 3, immagine 3 di 3
    • Remove the belt that's to the right of where the brush roll was by pulling the bottom off of the pin.
Conclusione
Cal Poly, Team S11-G2, Banghart Winter 2018 Membro di Cal Poly, Team S11-G2, Banghart Winter 2018
CPSU-BANGHART-W18S11G2
5 Membri
9 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 16
Tutti i Tempi: 2,517
