Salta al contenuto principale
Hoover T-Series WindTunnel Pet UH30310 Vacuum Belt Replacement
Cosa ti serve
  1. Hoover T-Series WindTunnel Pet UH30310 Vacuum Belt Replacement, Brush: passo 1, immagine 1 di 2 Hoover T-Series WindTunnel Pet UH30310 Vacuum Belt Replacement, Brush: passo 1, immagine 2 di 2
    • Place the vacuum on its back.
    • On the bottom right side, push the red lever to the left.
    • Remove the plastic cover.
  2. Hoover T-Series WindTunnel Pet UH30310 Vacuum Belt Replacement: passo 2, immagine 1 di 3 Hoover T-Series WindTunnel Pet UH30310 Vacuum Belt Replacement: passo 2, immagine 2 di 3 Hoover T-Series WindTunnel Pet UH30310 Vacuum Belt Replacement: passo 2, immagine 3 di 3
    • Grab the red switch under the brush and push left.
    • Then remove the plastic base plate.
  3. Hoover T-Series WindTunnel Pet UH30310 Vacuum Belt Replacement: passo 3, immagine 1 di 3 Hoover T-Series WindTunnel Pet UH30310 Vacuum Belt Replacement: passo 3, immagine 2 di 3 Hoover T-Series WindTunnel Pet UH30310 Vacuum Belt Replacement: passo 3, immagine 3 di 3
    • Use a Phillips #1 screwdriver to remove the two screws on the right side of the brush.
  4. Hoover T-Series WindTunnel Pet UH30310 Vacuum Belt Replacement: passo 4, immagine 1 di 3 Hoover T-Series WindTunnel Pet UH30310 Vacuum Belt Replacement: passo 4, immagine 2 di 3 Hoover T-Series WindTunnel Pet UH30310 Vacuum Belt Replacement: passo 4, immagine 3 di 3
    • Remove the two screws on the left side of the brush.
  5. Hoover T-Series WindTunnel Pet UH30310 Vacuum Belt Replacement: passo 5, immagine 1 di 3 Hoover T-Series WindTunnel Pet UH30310 Vacuum Belt Replacement: passo 5, immagine 2 di 3 Hoover T-Series WindTunnel Pet UH30310 Vacuum Belt Replacement: passo 5, immagine 3 di 3
    • Pull the clear plastic away from the head of the vacuum.
    • Slide the belt off the metal rod with your finger.
    • Pull the brush free.
  6. Hoover T-Series WindTunnel Pet UH30310 Vacuum Belt Replacement, Vacuum Belt: passo 6, immagine 1 di 1
    • Removal of the brush will also remove the belt.
Conclusione
Erik Ingels
Membro da: 01/18/18
193 Reputazione
2 Guide realizzate
Cal Poly, Team S12-G4, Banghart Winter 2018 Membro di Cal Poly, Team S12-G4, Banghart Winter 2018
CPSU-BANGHART-W18S12G4
5 Membri
9 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 4
Tutti i Tempi: 785
