Salta al contenuto principale
Hoover Presto 2-in-1 Cordless Stick HEPA Filter Replacement
  1. Hoover Presto 2-in-1 Cordless Stick HEPA Filter Replacement, HEPA Filter: passo 1, immagine 1 di 3 Hoover Presto 2-in-1 Cordless Stick HEPA Filter Replacement, HEPA Filter: passo 1, immagine 2 di 3 Hoover Presto 2-in-1 Cordless Stick HEPA Filter Replacement, HEPA Filter: passo 1, immagine 3 di 3
    • Using your hands, gently pull the hand vacuum away from the stick vacuum to detach.
  2. Hoover Presto 2-in-1 Cordless Stick HEPA Filter Replacement: passo 2, immagine 1 di 2 Hoover Presto 2-in-1 Cordless Stick HEPA Filter Replacement: passo 2, immagine 2 di 2
    • Press the hand vacuum's gray release button located directly below the power button to release the dust container from the hand vacuum.
    • Gently pull off the dust container with your other hand.
  3. Hoover Presto 2-in-1 Cordless Stick HEPA Filter Replacement: passo 3, immagine 1 di 2 Hoover Presto 2-in-1 Cordless Stick HEPA Filter Replacement: passo 3, immagine 2 di 2
    • Remove HEPA filter from dust pan by pulling gently.
  4. Hoover Presto 2-in-1 Cordless Stick HEPA Filter Replacement: passo 4, immagine 1 di 2 Hoover Presto 2-in-1 Cordless Stick HEPA Filter Replacement: passo 4, immagine 2 di 2
    • Separate the cyclonic separator from the HEPA filter by pulling apart.
  5. Hoover Presto 2-in-1 Cordless Stick HEPA Filter Replacement: passo 5, immagine 1 di 2 Hoover Presto 2-in-1 Cordless Stick HEPA Filter Replacement: passo 5, immagine 2 di 2
    • Hold the HEPA dust filter over trash bin and gently shake to clean. Use hands to rub off dirt/dust if necessary.
Conclusione
katia zubieta
Membro da: 09/11/17
437 Reputazione
4 Guide realizzate
Un commento
Necesito bateria hoover presto 2 en 1 14.4v 1400 mah
cpeza - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 13
Tutti i Tempi: 661
