Salta al contenuto principale
Hoover Presto 2-in-1 Cordless Stick Charger Replacement
Cosa ti serve
  1. Hoover Presto 2-in-1 Cordless Stick Charger Replacement, Charger Electronic Module: passo 1, immagine 1 di 3 Hoover Presto 2-in-1 Cordless Stick Charger Replacement, Charger Electronic Module: passo 1, immagine 2 di 3 Hoover Presto 2-in-1 Cordless Stick Charger Replacement, Charger Electronic Module: passo 1, immagine 3 di 3
    • Using a firm grip, gently pull the standing charger away from the floor charger attachment
  2. Hoover Presto 2-in-1 Cordless Stick Charger Replacement: passo 2, immagine 1 di 2 Hoover Presto 2-in-1 Cordless Stick Charger Replacement: passo 2, immagine 2 di 2
    • Flip the floor charger over so the screws and sticker are facing you
    • Using a PH #1 screw driver, remove the two 18mm screws on the right hand side of the floor charger
  3. Hoover Presto 2-in-1 Cordless Stick Charger Replacement: passo 3, immagine 1 di 2 Hoover Presto 2-in-1 Cordless Stick Charger Replacement: passo 3, immagine 2 di 2
    • Using a PH #2 screw driver, remove the three 18mm screws on floor charger.
  4. Hoover Presto 2-in-1 Cordless Stick Charger Replacement: passo 4, immagine 1 di 2 Hoover Presto 2-in-1 Cordless Stick Charger Replacement: passo 4, immagine 2 di 2
    • Using the metal spudger tool, gently lift up the plastic cover in the upper right hand corner of the floor attachment to uncover a hidden screw
    • Remove the 18mm screw in the upper right hand corner with a PH #1 screw driver
  5. Hoover Presto 2-in-1 Cordless Stick Charger Replacement: passo 5, immagine 1 di 2 Hoover Presto 2-in-1 Cordless Stick Charger Replacement: passo 5, immagine 2 di 2
    • Using the metal spudger, gently pry open the two halves of the floor charger
    • Once you have made a larger enough gap between the two halves, use your hands and gently pull the rest of the floor charger apart
  6. Hoover Presto 2-in-1 Cordless Stick Charger Replacement: passo 6, immagine 1 di 1
    • Unscrew the two 18mm screws on either side of the white battery cover with a PH #1 screw driver
  7. Hoover Presto 2-in-1 Cordless Stick Charger Replacement: passo 7, immagine 1 di 2 Hoover Presto 2-in-1 Cordless Stick Charger Replacement: passo 7, immagine 2 di 2
    • Using your hands, gently pull apart the two halves of the white battery cover to get to the battery
Conclusione
katia zubieta
Membro da: 09/11/17
437 Reputazione
4 Guide realizzate
4 Commenti
La pila dónde la puedo encontrar
alejandro rodriguez - Replica
De la aspiradora Hoover presto 2 un 1
I followed the directions above and got it opened. There was no battery inside. What do I do???? This is for the Hoover Presto 2in1. Thank you.
silvmarg - Replica
Where does one buy the replacement battery?
mytikikitty - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 28
Tutti i Tempi: 6,085
