Salta al contenuto principale
Hoover Power Path Pro Advanced Power Switch Replacement
Cosa ti serve
  1. Hoover Power Path Pro Advanced Power Switch Replacement, Power Switch: passo 1, immagine 1 di 1
    • Remove the lower brushroll from the bottom of the cleaner.
  2. Hoover Power Path Pro Advanced Power Switch Replacement: passo 2, immagine 1 di 1
    • Use a long #2 Philips head to remove the 8 numbered screws on the bottom of the cleaner (They will also be indicated on the bottom of the vacuum).
  3. Hoover Power Path Pro Advanced Power Switch Replacement: passo 3, immagine 1 di 2 Hoover Power Path Pro Advanced Power Switch Replacement: passo 3, immagine 2 di 2
    • Pull the red handle to remove the front suction unit from the cleaner.
  4. Hoover Power Path Pro Advanced Power Switch Replacement: passo 4, immagine 1 di 1
    • Unscrew the hose by using a Phillips #2 to detach it from the top cover of the cleaner.
  5. Hoover Power Path Pro Advanced Power Switch Replacement: passo 5, immagine 1 di 2 Hoover Power Path Pro Advanced Power Switch Replacement: passo 5, immagine 2 di 2
    • Push down on the handle release button. Lift the edge of top cover connected to this button.
    • Repeat the above step for the "On/Off" button.
    • Pull entire top cover off.
    • Caution: when pulling the handle release button, make sure the top of the cleaner does not fall.
  6. Hoover Power Path Pro Advanced Power Switch Replacement: passo 6, immagine 1 di 1
    • Remove the "On/Off" cap by pulling it upwards with caution.
  7. Hoover Power Path Pro Advanced Power Switch Replacement: passo 7, immagine 1 di 1
    • Use a long #2 Philips head to remove the two screws from the arched grey piece.
  8. Hoover Power Path Pro Advanced Power Switch Replacement: passo 8, immagine 1 di 2 Hoover Power Path Pro Advanced Power Switch Replacement: passo 8, immagine 2 di 2
    • Pull out the red power the red power switch.
Conclusione
Altre 4 persone hanno completato questa guida.
3Commenti sulla guida
What is the part number?
martahayner - Replica
Thanks so much!!
debmccrimm - Replica
you have to test the switch, mine tested ok which led me to the fuse between the motor and switch. It was bad, parts warehouse part # 440004065 does the trick.
frank - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 26
Tutti i Tempi: 4,018
