Salta al contenuto principale
Introduzione
This guide will show you how to replace the nozzle prongs in the motor in the nozzle. This guide would be needed if the prongs on your device are bent out of shape or if they are not transmitting power to the brush roll motor. Remember to remove thee battery from the device before starting this guide.
Parti
Nessuna parte specificata.
  1. Detach the rolling assembly  from the body by pushing the button found at the base.
    • Detach the rolling assembly from the body by pushing the button found at the base.
  2. Remove the seven 7.5mm Phillips #1 screws from the brush retainer.
    • Remove the seven 7.5mm Phillips #1 screws from the brush retainer.
  3. Remove the brush and retainer from the rolling assembly. The brush will need to be disconnected from the belt.
    • Remove the brush and retainer from the rolling assembly.
    • The brush will need to be disconnected from the belt.
  4. Remove the eight 4mm Phillips #1 screws from the bottom panel.
    • Remove the eight 4mm Phillips #1 screws from the bottom panel.
  5. Kit riparazione batterie MacBook
    A partire da $69.99
    Buy Now
    A partire da $69.99
    Buy Now
  6. Remove the bottom panel.
    • Remove the bottom panel.
  7. Remove the motor.
    • Remove the motor.
  8. Remove the two 7.5mm Phillips #1 screws from the main body.
    • Remove the two 7.5mm Phillips #1 screws from the main body.
  9. Remove the black covering from the air tube.
    • Remove the black covering from the air tube.
  10. Slide the prongs out through their channels.
    • Slide the prongs out through their channels.
  11. Remove the angled neck and feed the prongs out through their channels. Remove the angled neck and feed the prongs out through their channels.
    • Remove the angled neck and feed the prongs out through their channels.
  12. Replace the prongs. Replace the prongs.
    • Replace the prongs.
Conclusione
Sara Vlhova
Membro da: 25/01/2018
496 Reputazione
4 Guide realizzate
USF Tampa, Team S7-G4, Passmore Spring 2018 Membro di USF Tampa, Team S7-G4, Passmore Spring 2018
USFT-PASSMORE-S18S7G4
4 Membri
6 Guide realizzate
How do I get to the receivers for the prongs? They appear to be too loose to make a connection and i have not been able to get into the body to tighten. Is there another way to improve this connection?
Robert L Worthing - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 10
Tutti i Tempi: 158
