Salta al contenuto principale
Aggiusta la tua roba
Diritto alla Riparazione
Store
Introduzione
This guide will show you how to open dissemble the handle and replace the motherboard. You might need to do this if the device has power but fails to turn on. Remember to remove the battery from the device.
  1. Remove the single 15mm Phillips #1 screw from the handle.
    • Remove the single 15mm Phillips #1 screw from the handle.
  2. Remove the handle by pulling it up.
    • Remove the handle by pulling it up.
  3. Remove two 15mm Phillips #1 screws from the handle.
    • Remove two 15mm Phillips #1 screws from the handle.
  4. Use a plastic opening tool to carefully pry the black cover off of the handle. Use a plastic opening tool to carefully pry the black cover off of the handle.
    • Use a plastic opening tool to carefully pry the black cover off of the handle.
  5. Remove five 15mm Phillips #1 black screws from the handle. Remove five 15mm Phillips #1 black screws from the handle.
    • Remove five 15mm Phillips #1 black screws from the handle.
  6. Remove the silver plastic cover using the plastic opening tool. Remove the silver plastic cover using the plastic opening tool.
    • Remove the silver plastic cover using the plastic opening tool.
  7. Remove the black rubber cover from the motherboard.
    • Remove the black rubber cover from the motherboard.
  8. Remove two 8mm Phillips #1 screws from the motherboard.
    • Remove two 8mm Phillips #1 screws from the motherboard.
  9. Carefully pull the motherboard out with its attached wires. Carefully pull the motherboard out with its attached wires.
    • Carefully pull the motherboard out with its attached wires.
Conclusione
Sara Vlhova
Membro da: 25/01/2018
511 Reputazione
4 Guide realizzate
USF Tampa, Team S7-G4, Passmore Spring 2018 Membro di USF Tampa, Team S7-G4, Passmore Spring 2018
USFT-PASSMORE-S18S7G4
4 Membri
6 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 13
Tutti i Tempi: 455
