Salta al contenuto principale
Honeywell HY-204 Fan Motor Replacement
Cosa ti serve
  1. Honeywell HY-204 Fan Motor Replacement, Case: passo 1, immagine 1 di 2 Honeywell HY-204 Fan Motor Replacement, Case: passo 1, immagine 2 di 2
    • Before you begin, be sure to unplug the fan.
    • Remove the four 14 mm screws from the back of the device using the Phillips #0 Screwdriver.
  2. Honeywell HY-204 Fan Motor Replacement: passo 2, immagine 1 di 2 Honeywell HY-204 Fan Motor Replacement: passo 2, immagine 2 di 2
    • Pull the front and back parts of the case away from each other until the back is free from the front. This may require a large amount of force.
  3. Honeywell HY-204 Fan Motor Replacement, Fan Blades: passo 3, immagine 1 di 2 Honeywell HY-204 Fan Motor Replacement, Fan Blades: passo 3, immagine 2 di 2
    • Remove the hex nut from the fan motor with a 10mm hexagonal ratcheting socket wrench.
    • The nut uses a left-handed thread.
  4. Honeywell HY-204 Fan Motor Replacement: passo 4, immagine 1 di 2 Honeywell HY-204 Fan Motor Replacement: passo 4, immagine 2 di 2
    • Grasp the fan blade firmly and pull upward to remove it from the center column of the fan.
    • The slots on the fan blades and center column need to be aligned for reassembly.
  5. Honeywell HY-204 Fan Motor Replacement, Fan Motor: passo 5, immagine 1 di 2 Honeywell HY-204 Fan Motor Replacement, Fan Motor: passo 5, immagine 2 di 2
    • Remove the four 12.7mm screws using the Phillips #0 Screwdriver.
    • Once the screws are removed, lift the motor off its base.
  6. Honeywell HY-204 Fan Motor Replacement: passo 6, immagine 1 di 2 Honeywell HY-204 Fan Motor Replacement: passo 6, immagine 2 di 2
    • Remove the wire connectors from the black, brown, red, blue, white, grey, and green wires. To do this, grip each wire with your hand and use the pliers to de-crimp the heads of each wire connector by applying pressure to the wider ends of the connector until it falls free.
    • While reassembling, apply pressure to the more narrow ends of the wire connectors to re-crimp them onto the wires.
Conclusione
Altre 2 persone hanno completato questa guida.
Cal Poly, Team 10-40, Amido Fall 2014 Membro di Cal Poly, Team 10-40, Amido Fall 2014
CPSU-AMIDO-F14S10G40
3 Membri
7 Guide realizzate
2 Commenti
Where do you purchase the replacement fan motors from?
mattb - Replica
Do you know where I can find the fan motor replacement?
Dave Smith - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 5
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 17
Tutti i Tempi: 6,641
