Salta al contenuto principale
Honeywell HY-204 Fan Blades Replacement
Cosa ti serve
  1. Honeywell HY-204 Fan Blades Replacement, Case: passo 1, immagine 1 di 2 Honeywell HY-204 Fan Blades Replacement, Case: passo 1, immagine 2 di 2
    • Before you begin, be sure to unplug the fan.
    • Remove the four 14 mm screws from the back of the device using the Phillips #0 Screwdriver.
  2. Honeywell HY-204 Fan Blades Replacement: passo 2, immagine 1 di 2 Honeywell HY-204 Fan Blades Replacement: passo 2, immagine 2 di 2
    • Pull the front and back parts of the case away from each other until the back is free from the front. This may require a large amount of force.
  3. Honeywell HY-204 Fan Blades Replacement, Fan Blades: passo 3, immagine 1 di 2 Honeywell HY-204 Fan Blades Replacement, Fan Blades: passo 3, immagine 2 di 2
    • Remove the hex nut from the fan motor with a 10mm hexagonal ratcheting socket wrench.
    • The nut uses a left-handed thread.
  4. Honeywell HY-204 Fan Blades Replacement: passo 4, immagine 1 di 2 Honeywell HY-204 Fan Blades Replacement: passo 4, immagine 2 di 2
    • Grasp the fan blade firmly and pull upward to remove it from the center column of the fan.
    • The slots on the fan blades and center column need to be aligned for reassembly.
Conclusione
Cal Poly, Team 10-40, Amido Fall 2014 Membro di Cal Poly, Team 10-40, Amido Fall 2014
CPSU-AMIDO-F14S10G40
3 Membri
7 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 6
Tutti i Tempi: 3,130
