Salta al contenuto principale
Honeywell HY-204 Control Panel Replacement
Cosa ti serve
  1. Honeywell HY-204 Control Panel Replacement, Case: passo 1, immagine 1 di 2 Honeywell HY-204 Control Panel Replacement, Case: passo 1, immagine 2 di 2
    • Before you begin, be sure to unplug the fan.
    • Remove the four 14 mm screws from the back of the device using the Phillips #0 Screwdriver.
  2. Honeywell HY-204 Control Panel Replacement: passo 2, immagine 1 di 2 Honeywell HY-204 Control Panel Replacement: passo 2, immagine 2 di 2
    • Pull the front and back parts of the case away from each other until the back is free from the front. This may require a large amount of force.
  3. Honeywell HY-204 Control Panel Replacement, Control Panel: passo 3, immagine 1 di 2 Honeywell HY-204 Control Panel Replacement, Control Panel: passo 3, immagine 2 di 2
    • Remove the two 3mm screws found just below the top of the device using the Phillips #0 Screwdriver.
  4. Honeywell HY-204 Control Panel Replacement: passo 4, immagine 1 di 1
    • Pry off the control panel by forcefully lifting the tab located inside the front of the fan with the plastic opening tool.
Conclusione
Cal Poly, Team 10-40, Amido Fall 2014 Membro di Cal Poly, Team 10-40, Amido Fall 2014
CPSU-AMIDO-F14S10G40
3 Membri
7 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 8
Tutti i Tempi: 527
