Salta al contenuto principale
Honeywell Fan Plug Replacement
Cosa ti serve
  1. Honeywell Fan  Plug Replacement, Plug: passo 1, immagine 1 di 2 Honeywell Fan  Plug Replacement, Plug: passo 1, immagine 2 di 2
    • Make sure to unplug the Fan.
    • Cut off the old damaged plug from the fan using a pair of wire cutters.
  2. Honeywell Fan  Plug Replacement: passo 2, immagine 1 di 2 Honeywell Fan  Plug Replacement: passo 2, immagine 2 di 2
    • Separate the wires by pulling them apart.
    • The hot wire has smooth insulation.
    • The neutral wire has small ridges in the insulation.
  3. Honeywell Fan  Plug Replacement: passo 3, immagine 1 di 2 Honeywell Fan  Plug Replacement: passo 3, immagine 2 di 2
    • Measure 3/4" inch of the wire.
    • Strip 3/4" of the insulation to expose the copper wire.
  4. Honeywell Fan  Plug Replacement: passo 4, immagine 1 di 2 Honeywell Fan  Plug Replacement: passo 4, immagine 2 di 2
    • Open the new plug by loosening the screws with a Phillips #0 screwdriver.
    • The silver screw is the neutral wire connection.
    • The brass screw is the hot wire connection.
    • The two different connections must be determined to wire the new plug correctly.
  5. Honeywell Fan  Plug Replacement: passo 5, immagine 1 di 2 Honeywell Fan  Plug Replacement: passo 5, immagine 2 di 2
    • Twist the ends of the copper wires.
    • Twisting the wires will ensure safety while screwing the wires and reliable connection.
    • Insert the twisted wires to each of the screws.
    • The hot wire will be connected to the brass screw and has smooth insulation.
    • The neutral wire will be connected to silver screw and has small ridged insulation.
  6. Honeywell Fan  Plug Replacement: passo 6, immagine 1 di 3 Honeywell Fan  Plug Replacement: passo 6, immagine 2 di 3 Honeywell Fan  Plug Replacement: passo 6, immagine 3 di 3
    • Tighten each of the screws with a Phillips #0 screwdriver.
    • Close the cover of the plug.
    • Tighten the exterior screws of the plug with a Phillips #0 screwdriver to close the plug.
Conclusione
Anmol Brar
Membro da: 04/29/20
160 Reputazione
1 Guida realizzata
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 61
Tutti i Tempi: 4,833
