Salta al contenuto principale
Honda Lawn Mower HRS216K6 PKAA Flywheel Key Replacement
Cosa ti serve
    1. Honda Lawn Mower HRS216K6 PKAA Flywheel Key Replacement, Disconnect the spark plug: passo 1, immagine 1 di 2 Honda Lawn Mower HRS216K6 PKAA Flywheel Key Replacement, Disconnect the spark plug: passo 1, immagine 2 di 2
      • Before you begin, make sure the engine is switched off and cool to the touch.
      • Grab the plastic housing at the end of the spark plug wire and pull firmly to disconnect it.
      Chiedi a FixBot
      Aggiungi Commento
    2. Honda Lawn Mower HRS216K6 PKAA Flywheel Key Replacement, Restrict fuel flow: passo 2, immagine 1 di 1
      • Turn the fuel cutoff valve to the off position to restrict fuel flow during disassembly.
      • Turn the fuel cutoff valve clockwise so the handle becomes vertical.
      Chiedi a FixBot
      Aggiungi Commento
    1. Honda Lawn Mower HRS216K6 PKAA Flywheel Key Replacement, Disconnect the fuel tank: passo 3, immagine 1 di 3 Honda Lawn Mower HRS216K6 PKAA Flywheel Key Replacement, Disconnect the fuel tank: passo 3, immagine 2 di 3 Honda Lawn Mower HRS216K6 PKAA Flywheel Key Replacement, Disconnect the fuel tank: passo 3, immagine 3 di 3
      • Use needle nose pliers to compress and slide the tube clamp away from the cutoff valve's fitting.
      Chiedi a FixBot
      Aggiungi Commento
    2. Honda Lawn Mower HRS216K6 PKAA Flywheel Key Replacement: passo 4, immagine 1 di 2 Honda Lawn Mower HRS216K6 PKAA Flywheel Key Replacement: passo 4, immagine 2 di 2
      • Residual fuel may leak out of this hose. Be ready to catch any spillage.
      • Disconnect the fuel line from the cutoff valve.
      Chiedi a FixBot
      Aggiungi Commento
    3. Honda Lawn Mower HRS216K6 PKAA Flywheel Key Replacement, Disconnect the brake cable: passo 5, immagine 1 di 1
      • Use needle nose pliers to squeeze the two locking tabs on the brake cable latch.
      Chiedi a FixBot
      Aggiungi Commento
    4. Honda Lawn Mower HRS216K6 PKAA Flywheel Key Replacement: passo 6, immagine 1 di 3 Honda Lawn Mower HRS216K6 PKAA Flywheel Key Replacement: passo 6, immagine 2 di 3 Honda Lawn Mower HRS216K6 PKAA Flywheel Key Replacement: passo 6, immagine 3 di 3
      • Pull to unlatch the cable sheath.
      • Pull the brake cable away from the motor.
      Chiedi a FixBot
      Aggiungi Commento
    5. Honda Lawn Mower HRS216K6 PKAA Flywheel Key Replacement: passo 7, immagine 1 di 3 Honda Lawn Mower HRS216K6 PKAA Flywheel Key Replacement: passo 7, immagine 2 di 3 Honda Lawn Mower HRS216K6 PKAA Flywheel Key Replacement: passo 7, immagine 3 di 3
      • Push the cable towards the cable anchor to give it enough slack to be removed.
      • Remove the brake cable from the motor.
      Chiedi a FixBot
      Aggiungi Commento
    6. Honda Lawn Mower HRS216K6 PKAA Flywheel Key Replacement, Disconnect the pull start cord: passo 8, immagine 1 di 3 Honda Lawn Mower HRS216K6 PKAA Flywheel Key Replacement, Disconnect the pull start cord: passo 8, immagine 2 di 3 Honda Lawn Mower HRS216K6 PKAA Flywheel Key Replacement, Disconnect the pull start cord: passo 8, immagine 3 di 3
      • Pull the pull start cord out of the small opening on the handle post and remove it.
      Chiedi a FixBot
      Aggiungi Commento
    7. Honda Lawn Mower HRS216K6 PKAA Flywheel Key Replacement, Remove the fan cover: passo 9, immagine 1 di 1
      • Remove the three 10 mm nuts securing the fan cover.
      Chiedi a FixBot
      Aggiungi Commento
    8. Honda Lawn Mower HRS216K6 PKAA Flywheel Key Replacement: passo 10, immagine 1 di 2 Honda Lawn Mower HRS216K6 PKAA Flywheel Key Replacement: passo 10, immagine 2 di 2
      • Remove the fan cover.
      • The fuel tank is connected to the fan cover. They will both come out as one unit.
      Chiedi a FixBot
      Aggiungi Commento
    1. Honda Lawn Mower HRS216K6 PKAA Flywheel Key Replacement, Remove the cooling fan: passo 11, immagine 1 di 1
      • Remove the 19 mm nut securing the flywheel and cooling fan to the motor.
      Chiedi a FixBot
      Aggiungi Commento
    2. Honda Lawn Mower HRS216K6 PKAA Flywheel Key Replacement: passo 12, immagine 1 di 2 Honda Lawn Mower HRS216K6 PKAA Flywheel Key Replacement: passo 12, immagine 2 di 2
      • Remove the washer on top of the cooling fan.
      • Remove the cooling fan.
      Chiedi a FixBot
      Aggiungi Commento
    1. Honda Lawn Mower HRS216K6 PKAA Flywheel Key Replacement, Loosen the flywheel: passo 13, immagine 1 di 2 Honda Lawn Mower HRS216K6 PKAA Flywheel Key Replacement, Loosen the flywheel: passo 13, immagine 2 di 2
      • Caution: The flywheel may come loose at any time during this step, potentially sending itself and the puller into the air. Before you begin this step, be sure to wear PPE.
      • Use a universal puller to loosen the flywheel from the tapered pressure fit on the end of the crankshaft.
      • Attach the universal puller arms underneath the denoted "puller" sections on the flywheel.
      • Use a wrench to torque down the puller to slowly loosen the flywheel.
      • This may take a lot of force.
      • If the flywheel seems to become stuck after significant pressure is applied with the universal puller, use a blowtorch to slowly apply heat where the flywheel contacts the crankshaft.
      • The flywheel will "pop" off the crankshaft once loose.
      Chiedi a FixBot
      Aggiungi Commento
    2. Honda Lawn Mower HRS216K6 PKAA Flywheel Key Replacement, Remove the flywheel: passo 14, immagine 1 di 3 Honda Lawn Mower HRS216K6 PKAA Flywheel Key Replacement, Remove the flywheel: passo 14, immagine 2 di 3 Honda Lawn Mower HRS216K6 PKAA Flywheel Key Replacement, Remove the flywheel: passo 14, immagine 3 di 3
      • Remove the flywheel.
      • If the flywheel became deformed at all during the last step, it will need to be replaced before reinstallation.
      • During reassembly, make sure to align the flywheel with the flywheel key.
      Chiedi a FixBot
      Aggiungi Commento
    1. Honda Lawn Mower HRS216K6 PKAA Flywheel Key Replacement, Remove the flywheel key: passo 15, immagine 1 di 2 Honda Lawn Mower HRS216K6 PKAA Flywheel Key Replacement, Remove the flywheel key: passo 15, immagine 2 di 2
      • Use needle nose pliers to remove the flywheel key from its slot in the crankshaft.
      • During reinstallation, make sure the key is fully seated in the slot. Otherwise the flywheel will not fit correctly.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
Altre 3 persone hanno completato questa guida.
Carsten Frauenheim
Membro da: 03/10/20
171.088 Reputazione
442 guide realizzate
iFixit Membro di iFixit
Staff
122 Membri
86.613 guide realizzate
1Commento della guida
These instructions were very good for me. My Honda lawn mower is not starting. I presume it is a sheared key, but the key doesn't have jagged edges like it broke or any stress was applied to it.
Bryan Abney - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 4
Ultimi 7 giorni: 35
Ultimi 30 giorni: 126
Tutti i Tempi: 3,754
