Salta al contenuto principale
Honda Fit Reset Oil Life Indicator Replacement
Cosa ti serve
    • Turn the key in the ignition to the run position (right before the start position)
    • Press the SELECT/RESET knob repeatedly until the engine oil life indicator is displayed.
    • Press and hold the SELECT/RESET knob for more than 10 seconds. The engine oil life indicator and the maintenance code(s) will blink.
    • Press and hold the SELECT/RESET knob for more than 5 seconds. The maintenance items code(s) will disappear, and the engine oil life will reset to 100%.
    • Turn the key in the ignition to the off position, and then start the engine to verify the indicator has been reset.
Conclusione
You did it!
Altre 19 persone hanno completato questa guida.
Jasen Friedle
Membro da: 08/25/14
3.821 Reputazione
3 Guide realizzate
5 Commenti
Great. I did it—and I’m a girl!!
pthompso99 - Replica
Excellent! Glad to hear it.
Jasen Friedle - Replica
in my case i followed the step through. 100% oil life was achieved but when i turn the ignition off and turn it back on to verify, it goes back to 15%
Esosa Aghimien - Replica
And how can I start the car that it won't start
sbukataake - Replica
Have you tried changing your blinker fluid?
neegnorg -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 14
Ultimi 7 Giorni: 87
Ultimi 30 Giorni: 522
Tutti i Tempi: 74,973
