Salta al contenuto principale
Honda CR-V Touring 2016 Cabin Air Filter Replacement
Cosa ti serve
  1. Honda CR-V Touring 2016 Cabin Air Filter Replacement, Cabin Air Filter: passo 1, immagine 1 di 3 Honda CR-V Touring 2016 Cabin Air Filter Replacement, Cabin Air Filter: passo 1, immagine 2 di 3 Honda CR-V Touring 2016 Cabin Air Filter Replacement, Cabin Air Filter: passo 1, immagine 3 di 3
    • Ensure that your 2016 Honda CR-V Touring Edition is off.
    • Open the glovebox and remove all of its contents.
  2. Honda CR-V Touring 2016 Cabin Air Filter Replacement: passo 2, immagine 1 di 3 Honda CR-V Touring 2016 Cabin Air Filter Replacement: passo 2, immagine 2 di 3 Honda CR-V Touring 2016 Cabin Air Filter Replacement: passo 2, immagine 3 di 3
    • Unfasten the hinge on the right side of your glovebox so the hook-part of the hinge is free and clear.
    • You may have to close the glovebox slightly, then open it fully while holding the hook to clear it.
  3. Honda CR-V Touring 2016 Cabin Air Filter Replacement: passo 3, immagine 1 di 2 Honda CR-V Touring 2016 Cabin Air Filter Replacement: passo 3, immagine 2 di 2
    • Push both sides of the glovebox together while lowering until the glovebox hangs at its lowest point.
    • This should allow access to the interior and give a clear line of sight to the cabin air filter holder.
  4. Honda CR-V Touring 2016 Cabin Air Filter Replacement: passo 4, immagine 1 di 3 Honda CR-V Touring 2016 Cabin Air Filter Replacement: passo 4, immagine 2 di 3 Honda CR-V Touring 2016 Cabin Air Filter Replacement: passo 4, immagine 3 di 3
    • Grasp both clasps on either side of the rectangular cabin air filter protective cover and pull to release the cover.
    • You should see a white filter.
  5. Honda CR-V Touring 2016 Cabin Air Filter Replacement: passo 5, immagine 1 di 2 Honda CR-V Touring 2016 Cabin Air Filter Replacement: passo 5, immagine 2 di 2
    • Pull the filter straight out until it is free and clear.
    • Be sure not to shake it to prevent any excess dust from falling.
  6. Honda CR-V Touring 2016 Cabin Air Filter Replacement: passo 6, immagine 1 di 3 Honda CR-V Touring 2016 Cabin Air Filter Replacement: passo 6, immagine 2 di 3 Honda CR-V Touring 2016 Cabin Air Filter Replacement: passo 6, immagine 3 di 3
    • Insert the new filter, taking care to orient the filter in the correct direction for airflow.
    • It will be marked with arrows both on the filter and below the location for the filter.
  7. Honda CR-V Touring 2016 Cabin Air Filter Replacement: passo 7, immagine 1 di 2 Honda CR-V Touring 2016 Cabin Air Filter Replacement: passo 7, immagine 2 di 2
    • Place the cabin air filter protective cover over top of the filter until you hear audible clicks from the clasps engaging.
  8. Honda CR-V Touring 2016 Cabin Air Filter Replacement: passo 8, immagine 1 di 2 Honda CR-V Touring 2016 Cabin Air Filter Replacement: passo 8, immagine 2 di 2
    • Push the glovebox up until you feel a detent where it is self supported but is not fully in the up-position.
  9. Honda CR-V Touring 2016 Cabin Air Filter Replacement: passo 9, immagine 1 di 2 Honda CR-V Touring 2016 Cabin Air Filter Replacement: passo 9, immagine 2 di 2
    • Re-clip the hook on the right side of the glovebox until it is fully engaged.
  10. Honda CR-V Touring 2016 Cabin Air Filter Replacement: passo 10, immagine 1 di 2 Honda CR-V Touring 2016 Cabin Air Filter Replacement: passo 10, immagine 2 di 2
    • Close the glovebox and you're all set!
Conclusione
Altre 2 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 34
Tutti i Tempi: 1,605
