Introduzione
This will be a guide on how to change the headlights in a Honda CRV. It is a fast fix and only requires a beginners level of car knowledge to complete.
Cosa ti serve
Go to your local auto shop and ask them to look up which headlights you will need for your specific car. They will give you the correct bulb and handling instructions.
Once the cover is off, the bulb will come out right into your hand.
Replace with a new bulb.
My CRV (2010) has a metal clip holding the bulb, you need to push it in (on the curved square tab part) towards the front of the car and lift up. then push back in and then down to clip it back in place.
3 Commenti
Haven’t done the repair yet BUT These instructions look very clear and concise with good illustrations. I detest having to go to U tube instructions!!
I don’t happen to have a computer screen with me when I work on my car.
2011 drivers side if you need more room you can release the fuse box from where it is attached to the metal bracket and move it somewhat out of the way. Took less than 15 minutes start to finish. Hope that helps. A YouTube video titled for bulb replacement showed removing bumper to free up headlight assembly to get at the bulbs. Overkill for the bulb but great video for replacement assembly.
