Introduzione
This guide shows how to remove and replace the control wire harness for the Honda EU3000IS1AWK 3000 watt generator.
This wire harness connects the control panel to the various generator assemblies.
You will need a long shaft (at least 5 inches) Phillips screwdriver in order to complete this guide.
You will also need some small zip ties to replace the ones that are removed during the procedure.
Cosa ti serve
Use a large flathead screwdriver to unlock the maintenance cover.
Open the maintenance cover.
Use a 10 mm socket to remove the four capped nuts securing the front cover.
Remove the front cover.
Use an 8 mm socket to disconnect the battery wires from the battery terminals.
Disconnect the black negative cable first to prevent the risk of shorting the battery.
Use a 10 mm socket to remove the four capped nuts securing the lower plate.
Remove the lower plate.
Insert a flathead screwdriver into the top of the brown fuse clip in order to release the fuse holder.
Detach the fuse holder from the brown clip.
Use pliers to lift and disconnect the choke cable from the choke stay.
Use a long shaft Phillips screwdriver to remove the deeply recessed screw securing the fuel cutoff switch.
Use a 10 mm socket to remove the four bolts securing the control panel.
Remove the following bolts securing the inverter:
One 8 mm ground bolt
Three 10 mm bolts (one behind the control panel)
Use a screwdriver to push the metal collar out of the center of the rubber mount.
To help keep track of the connectors, disconnect each one from the old harness and immediately connect it to the new harness.
