Salta al contenuto principale
Homtyler Stainless Steel Cat Water Fountain HT-CWF01 Water Pump Replacement
Cosa ti serve
  1. Homtyler Stainless Steel Cat Water Fountain HT-CWF01 Water Pump Replacement, Water Pump Replacement: passo 1, immagine 1 di 3 Homtyler Stainless Steel Cat Water Fountain HT-CWF01 Water Pump Replacement, Water Pump Replacement: passo 1, immagine 2 di 3 Homtyler Stainless Steel Cat Water Fountain HT-CWF01 Water Pump Replacement, Water Pump Replacement: passo 1, immagine 3 di 3
    • Unplug the fountain from the power source.
    • Pour out all the water and remove detachable parts like the lid, spout, and tray.
    • Place them on a towel to keep your workspace dry.
  2. Homtyler Stainless Steel Cat Water Fountain HT-CWF01 Water Pump Replacement: passo 2, immagine 1 di 2 Homtyler Stainless Steel Cat Water Fountain HT-CWF01 Water Pump Replacement: passo 2, immagine 2 di 2
    • Turn the tray over and gently lift the pump out of its slot.
    • Make sure the fountain is completely unplugged and dry before removing any parts to prevent electric shock.
    • Detach it carefully to avoid pulling on the cord or tubing.
  3. Homtyler Stainless Steel Cat Water Fountain HT-CWF01 Water Pump Replacement: passo 3, immagine 1 di 3 Homtyler Stainless Steel Cat Water Fountain HT-CWF01 Water Pump Replacement: passo 3, immagine 2 di 3 Homtyler Stainless Steel Cat Water Fountain HT-CWF01 Water Pump Replacement: passo 3, immagine 3 di 3
    • The tray has two layers; a top stainless steel cover and a bottom plastic base. Gently pull them apart.
    • Remove the faucet piece attached to the top and set it aside.
  4. Homtyler Stainless Steel Cat Water Fountain HT-CWF01 Water Pump Replacement: passo 4, immagine 1 di 3 Homtyler Stainless Steel Cat Water Fountain HT-CWF01 Water Pump Replacement: passo 4, immagine 2 di 3 Homtyler Stainless Steel Cat Water Fountain HT-CWF01 Water Pump Replacement: passo 4, immagine 3 di 3
    • There should be two sponge filters, take them both out one at a time.
    • You may replace them during reassembly if they appear worn out or dirty.
    • Replace both sponge filters at the same time to maintain steady water flow and cleanliness.
  5. Homtyler Stainless Steel Cat Water Fountain HT-CWF01 Water Pump Replacement: passo 5, immagine 1 di 3 Homtyler Stainless Steel Cat Water Fountain HT-CWF01 Water Pump Replacement: passo 5, immagine 2 di 3 Homtyler Stainless Steel Cat Water Fountain HT-CWF01 Water Pump Replacement: passo 5, immagine 3 di 3
    • Use a damp microfiber cloth to clean the trays thoroughly of any buildup, hair or residue.
  6. Homtyler Stainless Steel Cat Water Fountain HT-CWF01 Water Pump Replacement: passo 6, immagine 1 di 3 Homtyler Stainless Steel Cat Water Fountain HT-CWF01 Water Pump Replacement: passo 6, immagine 2 di 3 Homtyler Stainless Steel Cat Water Fountain HT-CWF01 Water Pump Replacement: passo 6, immagine 3 di 3
    • Take the old pump and open the top lid and then the inner lid.
    • Take a damp cloth or a Q-tip and clean the insides of the pump of any hair or debris.
    • You may either try cleaning the old pump first to see if it works or completely replace it with a new 'Homtyler Cat Water Fountain Replacement Pump'.
  7. Homtyler Stainless Steel Cat Water Fountain HT-CWF01 Water Pump Replacement: passo 7, immagine 1 di 3 Homtyler Stainless Steel Cat Water Fountain HT-CWF01 Water Pump Replacement: passo 7, immagine 2 di 3 Homtyler Stainless Steel Cat Water Fountain HT-CWF01 Water Pump Replacement: passo 7, immagine 3 di 3
    • Reassemble all parts in reverse order.
    • Fill the water storage tank with clean water.
    • Now when all the parts are properly attached, put the tray back on the tank.
    • Ensure that the pump completely submerges in water for it to work properly.
    • Plug in the fountain and check the water flow.
    • The fountain should start working instantly. Adjust the water level if needed.
Linea Traguardo
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 9
Tutti i Tempi: 59
