Salta al contenuto principale
Homelite UT44172 Plastic Casing Replacement
Cosa ti serve
  1. Homelite UT44172 Plastic Casing Replacement, Opening Device: passo 1, immagine 1 di 1
    • Remove the six 15 mm screws from the shear using a Phillips #2 screwdriver.
  2. Homelite UT44172 Plastic Casing Replacement, Remove Faceplate: passo 2, immagine 1 di 2 Homelite UT44172 Plastic Casing Replacement, Remove Faceplate: passo 2, immagine 2 di 2
    • Pull the faceplate away from the body of the device and replace it with the new faceplate.
    • Potential for device damage: Be sure to take caution of loose wires during the replacement process.
    • If the plate with the screw sockets was replaced, the wires will need to be put back into the the depressions on the new plate for the device to be closed up properly. See photo with the blades on the right for proper wire placement.
Conclusione
Adam soto
Membro da: 01/30/15
301 Reputazione
3 Guide realizzate
USF Tampa, Team 17-5, Watkins Winter 2015 Membro di USF Tampa, Team 17-5, Watkins Winter 2015
USFT-WATKINS-W15S17G5
3 Membri
4 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 4
Tutti i Tempi: 234
