Salta al contenuto principale
Homedics UHE-CMP15 Water Replacement
Cosa ti serve
  1. Homedics UHE-CMP15 Water Replacement, Water: passo 1, immagine 1 di 1
    • Unscrew the container from the lid.
    • Turn the cap counterclockwise and gently remove the lid from the container.
  2. Homedics UHE-CMP15 Water Replacement: passo 2, immagine 1 di 1
    • Remove the water that is already in the container and dump the old water into safe water disposal area.
    • Dump the old water outside or down the sink.
  3. Homedics UHE-CMP15 Water Replacement: passo 3, immagine 1 di 1
    • Clean out the container.
    • Use a towel, some soap, and water to clean out the container.
    • You can also use a mix of 50/50 white vinegar and water to clean.
    • Take the damp towel and move it along all off the container and then rinse it out with water.
  4. Homedics UHE-CMP15 Water Replacement: passo 4, immagine 1 di 1
    • Fill the container with fresh water.
    • Take some room temperature water from the sink and pour it into the clean container.
Conclusione
Dylan
Membro da: 10/30/23
337 Reputazione
3 Guide realizzate
UMass Dartmouth, Team 3-6, Konn Fall 2023 Membro di UMass Dartmouth, Team 3-6, Konn Fall 2023
UMASSD-KONN-F23S3G6
4 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 158
