Salta al contenuto principale
Homedics UHE-CMP15 Battery Replacement
Cosa ti serve
  1. Homedics UHE-CMP15 Battery Replacement, Battery: passo 1, immagine 1 di 1
    • Make sure your device is turned off by pressing the power button and ensuring the LED lights are off.
    • Unscrew top from the container by twisting the top of the container counter clockwise and pulling up.
  2. Homedics UHE-CMP15 Battery Replacement: passo 2, immagine 1 di 1
    • Flip the top portion upside down and remove the wick and wick holder.
    • To remove the wick pull on the wick holder and it should pop right off.
  3. Homedics UHE-CMP15 Battery Replacement: passo 3, immagine 1 di 2 Homedics UHE-CMP15 Battery Replacement: passo 3, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    • Using tweezers and or the spudging tool lift 3 small white rubber caps, pry underneath them and pull to remove them.
    • This reveals the three screws holding the cap in place.
  4. Homedics UHE-CMP15 Battery Replacement: passo 4, immagine 1 di 1
    • Unscrew and remove the 3 screws with a Philips head screwdriver. The screwdriver must be very long and thin.
    • Tilting the device upside down will slide the unscrewed screws out from the holes they are in after they are loosened.
  5. Homedics UHE-CMP15 Battery Replacement: passo 5, immagine 1 di 3 Homedics UHE-CMP15 Battery Replacement: passo 5, immagine 2 di 3 Homedics UHE-CMP15 Battery Replacement: passo 5, immagine 3 di 3
    • The top portion will now be able to be removed to reveal the inside of the battery compartment.
    • The battery is glued to the side wall with an adhesive pad.
    • This battery is hardwired in, and will require skill in soldering/wiring and the ability to find a suitable replacement.
Conclusione
UMass Dartmouth, Team 3-6, Konn Fall 2023 Membro di UMass Dartmouth, Team 3-6, Konn Fall 2023
UMASSD-KONN-F23S3G6
4 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 15
Tutti i Tempi: 274
