Salta al contenuto principale
Documento in evidenza
Questo smontaggio non è una guida di riparazione. Per riparare il tuo HomePod Mini, usa il nostro manuale di assistenza.
  1. HomePod Mini IC Identification, HomePod Mini IC Identification: passo 1, immagine 1 di 1
    • Side 1 IC Identification, Pt. 1:
    • Apple APL1W82 64-Bit Dual-Core Applications Processor w/ GPU with likely 1 Gb LPDDR3 SDRAM Memory
    • This is the same processor found in the Apple Watch Series 5, just not protected by a boatload of epoxy.
    • Apple 338S00553-A0 Power Management
    • Nordic Semiconductor nRF52833 Bluetooth 5.2 SoC w/ NFC and Zigbee
    • Skyworks SKY66404-11 2.4 GHz Zigbee/Thread/Bluetooth Front-End Module
    • USI 339M00117 WiFi/Bluetooth Module
    • USI UWB Transceiver
  2. HomePod Mini IC Identification: passo 2, immagine 1 di 1
    • Side 1 IC Identification, Pt. 2:
    • Analog Devices SSM3582A 31.76 W Filterless Stereo Class D Audio Amplifier
    • Texas Instruments CD3217B12 USB Type C Controller
    • Winbond W25Q80DVUXIE 8 Mb Serial NOR Flash Memory
    • Texas Instruments TPS62130B 3 A Step Down Converter
    • Texas Instruments INA199C3DCK Bi-Directional Current Sense Amplifier
    • Dialog Semiconductor SLG46140 Programmable Mixed Signal Array
    • 3 Likely Goertek MEMS Microphones are found around the perimeter of the PCB.
  3. HomePod Mini IC Identification: passo 3, immagine 1 di 1
    • Side 2 IC Identification:
    • Texas Instruments LP5030RJVR 30-Ch. Constant Current RGB LED Driver
    • Texas Instruments TPS55340RTE 5 A Boost Regulator
    • Austria Microsystems (AMS) Ambient Light Sensor
  4. HomePod Mini IC Identification: passo 4, immagine 1 di 3 HomePod Mini IC Identification: passo 4, immagine 2 di 3 HomePod Mini IC Identification: passo 4, immagine 3 di 3
    • Sensor Flex IC Identifications:
    • Texas Instruments HDC2010YPA Humidity/Temperature Sensor
    • Another likely Goertek MEMS Microphone
CChin
Membro da: 06/10/20
6.216 Reputazione
7 Guide realizzate
2 Commenti
nRF52833 is used for Thread networking protocol. Refer to HomePod mini tech spec: https://www.apple.com/homepod-mini/specs...
Henry Churchill - Replica
I wonder when are they gonna allow homekit to access the temperature and humidity sensors of the homepod mini?
Jeremy - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 6
Ultimi 7 Giorni: 31
Ultimi 30 Giorni: 185
Tutti i Tempi: 8,135
