Cosa ti serve
using your scissors, carefully cut through the fabric just enough so you can remove it from the speaker's body.
using your screwdriver, remove the 8 screws that are holding the speaker's body together.
using your spludger, carefully pry into the base.
using your screwdriver, remove the 6 screws that are holding the speaker in place.
using the spludger, carefully pry under the speaker to get it out.
carefully using 2 fingers, remove both of the connectors that connect to the speaker from the motherboard.
