Salta al contenuto principale
Holystone HS 440 Drone Battery Replacement
Cosa ti serve
  1. Holystone HS 440 Drone Battery Replacement, Drone Battery: passo 1, immagine 1 di 2 Holystone HS 440 Drone Battery Replacement, Drone Battery: passo 1, immagine 2 di 2
    • Pull the battery latch down and pull the battery out of the drone.
    • Make sure to turn off the drone before removing the battery.
  2. Holystone HS 440 Drone Battery Replacement: passo 2, immagine 1 di 2 Holystone HS 440 Drone Battery Replacement: passo 2, immagine 2 di 2
    • Use a Phillips #0 screwdriver to remove the four 4 mm Phillips #0 screws on the inside of the battery.
  3. Holystone HS 440 Drone Battery Replacement: passo 3, immagine 1 di 1
    • After removing the four screws, purchase the replacement battery from the HolyStone product page
    • It is recommeded to charge the new battery bank before inserting it back into the drone
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 13
Tutti i Tempi: 160
