Salta al contenuto principale
Holystone HS 440 Controller Phone Stand Replacement
Cosa ti serve
  1. Holystone HS 440 Controller Phone Stand Replacement, Controller Phone Stand: passo 1, immagine 1 di 3 Holystone HS 440 Controller Phone Stand Replacement, Controller Phone Stand: passo 1, immagine 2 di 3 Holystone HS 440 Controller Phone Stand Replacement, Controller Phone Stand: passo 1, immagine 3 di 3
    • Start by removing the battery lid on the back of the controller.
    • Make sure to remove all the AAA batteries before removing the back panel.
    • After removing the lid, take your Phillips #0 screwdriver and remove the two 2mm Phillips #0 screws located right below where the batteries go.
  2. Holystone HS 440 Controller Phone Stand Replacement: passo 2, immagine 1 di 3 Holystone HS 440 Controller Phone Stand Replacement: passo 2, immagine 2 di 3 Holystone HS 440 Controller Phone Stand Replacement: passo 2, immagine 3 di 3
    • Start prying the controller using the opening tool by sliding the tool through the breaks and applying some force to get it open. (it might require a bit of force)
    • After opening the controller, remove the four screws holding the phone stand and take the phone stand out.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 95
