Salta al contenuto principale
Holy Stone HS720 Rear Right Arm Replacement
Cosa ti serve
  1. Holy Stone HS720 Rear Right Arm Replacement, Remove the Battery: passo 1, immagine 1 di 1
    • Press down on the button and pull out the battery, to reveal 2 hidden screws.
  2. Holy Stone HS720 Rear Right Arm Replacement, Remove Screws x4: passo 2, immagine 1 di 3 Holy Stone HS720 Rear Right Arm Replacement, Remove Screws x4: passo 2, immagine 2 di 3 Holy Stone HS720 Rear Right Arm Replacement, Remove Screws x4: passo 2, immagine 3 di 3
    • Remove the 2 screws located under the battery
    • Remove the 2 screws on the sides of the drone, one on each side
  3. Holy Stone HS720 Rear Right Arm Replacement, Remove the top cover: passo 3, immagine 1 di 2 Holy Stone HS720 Rear Right Arm Replacement, Remove the top cover: passo 3, immagine 2 di 2
    • Gently pry on the top plastic cover to gain access to the main board.
    • There are 2 cables running from the back of the cover, do not accidentally tear them
    • Unplug the 2 cables, by gently prying on them, and remove the top cover of the drone
  4. Holy Stone HS720 Rear Right Arm Replacement, Locate and remove the correct wires: passo 4, immagine 1 di 3 Holy Stone HS720 Rear Right Arm Replacement, Locate and remove the correct wires: passo 4, immagine 2 di 3 Holy Stone HS720 Rear Right Arm Replacement, Locate and remove the correct wires: passo 4, immagine 3 di 3
    • Look closely at the images and locate the 7 wires that are connected to the arm
    • Take a photo of the board, so that you can resolder them back correctly later
    • Desolder the 7 wires
  5. Holy Stone HS720 Rear Right Arm Replacement, Remove the foot: passo 5, immagine 1 di 1
    • Remove the 2 screws that attach the rear right foot of the drone
    • Take the foot off, to reveal the arm spring
  6. Holy Stone HS720 Rear Right Arm Replacement, Remove the arm: passo 6, immagine 1 di 2 Holy Stone HS720 Rear Right Arm Replacement, Remove the arm: passo 6, immagine 2 di 2
    • Pry out the white plastic piece, to free the arm. (note: there are no screws holding it in)
    • Slowly pull the arm out, along with the wires connected to it
    • Repeat the steps in reverse order to reassemble the drone
Conclusione
Hope this helped :)
ugnoT
Membro da: 04/13/24
145 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 7
Tutti i Tempi: 116
