Salta al contenuto principale
Holmes box fan motor replacement
Cosa ti serve
  1. Holmes box fan motor replacement, Motor: passo 1, immagine 1 di 3 Holmes box fan motor replacement, Motor: passo 1, immagine 2 di 3 Holmes box fan motor replacement, Motor: passo 1, immagine 3 di 3
    • The first step is to make sure you unplug your fan from the outlet.
    • Make sure you also unplug the power cord from the back of the fan.
    My plug won’t unplug from the back of the fan what do I do? How should I try to get it out. The plug is really stuck in their.
    Marisol Walls - Replica
  2. Holmes box fan motor replacement: passo 2, immagine 1 di 2 Holmes box fan motor replacement: passo 2, immagine 2 di 2
    • Now that your fan is unplugged, lay it flat with the brand label facing upward.
    • Next is to remove the front cover.
    • Remove the six screws from the perimeter of the cover in order to remove the front cover.
  3. Holmes box fan motor replacement: passo 3, immagine 1 di 2 Holmes box fan motor replacement: passo 3, immagine 2 di 2
    • Next is the back cover.
    • Flip over the fan so you have access to these six screws.
    • Remove the six screws from the perimeter of the cover in order to remove the back cover.
  4. Holmes box fan motor replacement: passo 4, immagine 1 di 1
    • Remove these four screws in order to remove the motor and fan blades from the housing.
  5. Holmes box fan motor replacement: passo 5, immagine 1 di 1
    • The housing should now be able to lift away from the motor and fan blade.
  6. Holmes box fan motor replacement: passo 6, immagine 1 di 3 Holmes box fan motor replacement: passo 6, immagine 2 di 3 Holmes box fan motor replacement: passo 6, immagine 3 di 3
    • The next step is to remove the mounts that held the motor to the housing.
    • Remove these four screws to remove the mounts.
  7. Holmes box fan motor replacement: passo 7, immagine 1 di 2 Holmes box fan motor replacement: passo 7, immagine 2 di 2
    • Now you are able to remove the motor from the fan blades.
    • Be careful, if you used your fan recently the motor may be quite hot.
  8. Holmes box fan motor replacement: passo 8, immagine 1 di 1
    • Now you can insert your new motor and you are done!
Conclusione
Altre 6 persone hanno completato questa guida.
Max Cossalter
Membro da: 09/29/15
341 Reputazione
1 Guida realizzata
Cal Poly, Team 15-4, Green Fall 2015 Membro di Cal Poly, Team 15-4, Green Fall 2015
CPSU-GREEN-F15S15G4
4 Membri
4 Guide realizzate
5 Commenti
Where might one find a replacement motor for a older box fan
Chris Cook - Replica
Also, I would like to know where to get a replacement motor, as shown in step 4.
Vince Doriean - Replica
Great guide! Upon reassembling, I noticed that the center of the propeller touches the front grill where it says Holmes. Anyone know if they rub on each other by design?
Zeev - Replica
My version of the fan came with a similar cord, however the female end had a bump in the center on the end that latches into the fan. Without shaving that piece off, the plug doesn’t detach without taking it apart and prying it out.
applejack_ - Replica
Also want to know where to find this kind of replacement motor?
Bridget Alice Alonso - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 22
Tutti i Tempi: 13,009
