Salta al contenuto principale
Holmes HEH8031 Thermostat Replacement
Cosa ti serve
  1. Holmes HEH8031 Thermostat Replacement, Housing: passo 1, immagine 1 di 1
    • Ensure the device is unplugged from the wall outlet.
  2. Holmes HEH8031 Thermostat Replacement: passo 2, immagine 1 di 1
    • Remove eight 12-mm Phillips #2 screws from the back cover.
  3. Holmes HEH8031 Thermostat Replacement: passo 3, immagine 1 di 2 Holmes HEH8031 Thermostat Replacement: passo 3, immagine 2 di 2
    • Turn heater over so the controls are facing up.
    • Lift the front housing away from the back of the fan and slowly fold the front housing back down to the floor.
    • Internal wires are connected to both halves of the housing. Be careful when separating the housing.
  4. Holmes HEH8031 Thermostat Replacement, Circuit Board Removal: passo 4, immagine 1 di 1
    • Remove four 12mm Phillips #2 screws from the circuit board.
  5. Holmes HEH8031 Thermostat Replacement, Fan: passo 5, immagine 1 di 1
    • Remove two Phillips #2 12mm screws from housing
  6. Holmes HEH8031 Thermostat Replacement: passo 6, immagine 1 di 1
    • Remove zip tie from wire with pliers
  7. Holmes HEH8031 Thermostat Replacement: passo 7, immagine 1 di 1
    • Separate fan assembly from heating coil
  8. Holmes HEH8031 Thermostat Replacement, Thermostat: passo 8, immagine 1 di 1
    • Remove 1 Phillips #2 screw
  9. Holmes HEH8031 Thermostat Replacement: passo 9, immagine 1 di 1
    • Remove thermostat from rear housing
  10. Holmes HEH8031 Thermostat Replacement: passo 10, immagine 1 di 1
    • remove solder from thermostat wire on circuit board
    • Soldering iron will be hot
Conclusione
IUPUI, Team 2-1, Baechle Fall 2016 Membro di IUPUI, Team 2-1, Baechle Fall 2016
IUPUI-BAECHLE-F16S2G1
4 Membri
16 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 6
Tutti i Tempi: 1,279
