Salta al contenuto principale
Holmes HEH8031 Safety Weight Replacement
Cosa ti serve
  1. Holmes HEH8031 Safety Weight Replacement, Housing: passo 1, immagine 1 di 1
    • Ensure the device is unplugged from the wall outlet.
  2. Holmes HEH8031 Safety Weight Replacement: passo 2, immagine 1 di 1
    • Remove eight 12-mm Phillips #2 screws from the back cover.
  3. Holmes HEH8031 Safety Weight Replacement: passo 3, immagine 1 di 2 Holmes HEH8031 Safety Weight Replacement: passo 3, immagine 2 di 2
    • Turn heater over so the controls are facing up.
    • Lift the front housing away from the back of the fan and slowly fold the front housing back down to the floor.
    • Internal wires are connected to both halves of the housing. Be careful when separating the housing.
  4. Holmes HEH8031 Safety Weight Replacement, Circuit Board Removal: passo 4, immagine 1 di 1
    • Remove four 12mm Phillips #2 screws from the circuit board.
  5. Holmes HEH8031 Safety Weight Replacement, Safety Weight: passo 5, immagine 1 di 2 Holmes HEH8031 Safety Weight Replacement, Safety Weight: passo 5, immagine 2 di 2
    • Remove wires from safety weight, as shown.
    • Pull upward on the blue connectors.
    • If connectors are tough to remove, try wiggling while pulling upward.
  6. Holmes HEH8031 Safety Weight Replacement: passo 6, immagine 1 di 1
    • Unscrew the Phillips #2 10 mm screw from the safety weight on the rear housing panel.
Conclusione
Deanna Jack
Membro da: 10/12/16
333 Reputazione
4 Guide realizzate
IUPUI, Team 2-1, Baechle Fall 2016 Membro di IUPUI, Team 2-1, Baechle Fall 2016
IUPUI-BAECHLE-F16S2G1
4 Membri
16 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 5
Tutti i Tempi: 553
