Salta al contenuto principale
Holmes HEH8031 Power Cord Replacement
Cosa ti serve
  1. Holmes HEH8031 Power Cord Replacement, Housing: passo 1, immagine 1 di 1
    • Ensure the device is unplugged from the wall outlet.
  2. Holmes HEH8031 Power Cord Replacement: passo 2, immagine 1 di 1
    • Remove eight 12-mm Phillips #2 screws from the back cover.
  3. Holmes HEH8031 Power Cord Replacement: passo 3, immagine 1 di 2 Holmes HEH8031 Power Cord Replacement: passo 3, immagine 2 di 2
    • Turn heater over so the controls are facing up.
    • Lift the front housing away from the back of the fan and slowly fold the front housing back down to the floor.
    • Internal wires are connected to both halves of the housing. Be careful when separating the housing.
  4. Holmes HEH8031 Power Cord Replacement, Power Cord: passo 4, immagine 1 di 3 Holmes HEH8031 Power Cord Replacement, Power Cord: passo 4, immagine 2 di 3 Holmes HEH8031 Power Cord Replacement, Power Cord: passo 4, immagine 3 di 3
    • Decrimp the wire nuts from both wire connections.
    • Remove wire nuts to expose wire strands.
    • Separate all connected wires.
  5. Holmes HEH8031 Power Cord Replacement: passo 5, immagine 1 di 3 Holmes HEH8031 Power Cord Replacement: passo 5, immagine 2 di 3 Holmes HEH8031 Power Cord Replacement: passo 5, immagine 3 di 3
    • Pull on the cord from the outside of the heater with great finesse. At the same time, push the cord clamp out of the housing from the inside.
    • Separate the two halves of the cord clamp and remove from cord.
  6. Holmes HEH8031 Power Cord Replacement: passo 6, immagine 1 di 2 Holmes HEH8031 Power Cord Replacement: passo 6, immagine 2 di 2
    • Prepare the replacement cord by cutting the negative branch (black) at least 8 inches shorter than the positive branch (white).
    • Strip at least 3/4 inch of insulation from the cord to expose bare wire.
    • Twist wire ends to form a tight braid.
Conclusione
Altre 3 persone hanno completato questa guida.
Deanna Jack
Membro da: 10/12/16
333 Reputazione
4 Guide realizzate
IUPUI, Team 2-1, Baechle Fall 2016 Membro di IUPUI, Team 2-1, Baechle Fall 2016
IUPUI-BAECHLE-F16S2G1
4 Membri
16 Guide realizzate
Un commento
Are there substitute power cord for Holmes HEH8031 power cord replacement?
Terri Allen - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 16
Tutti i Tempi: 1,920
