Salta al contenuto principale
HoMedics TotalComfort UHE-CM18 Fan Replacement
Cosa ti serve
  1. HoMedics TotalComfort UHE-CM18 Fan Replacement, Fan: passo 1, immagine 1 di 2 HoMedics TotalComfort UHE-CM18 Fan Replacement, Fan: passo 1, immagine 2 di 2
    • Lift up the water tank and separate it from the humidifier.
    • Flip the humidifier over to its underside.
  2. HoMedics TotalComfort UHE-CM18 Fan Replacement: passo 2, immagine 1 di 2 HoMedics TotalComfort UHE-CM18 Fan Replacement: passo 2, immagine 2 di 2
    • Use the Phillips #1 screwdriver to remove the two 7 mm screws that secure the AC power plug.
    • Remove the AC power plug cover.
  3. HoMedics TotalComfort UHE-CM18 Fan Replacement: passo 3, immagine 1 di 2 HoMedics TotalComfort UHE-CM18 Fan Replacement: passo 3, immagine 2 di 2
    • Remove the remaining four 7 mm screws that hold the bottom cover.
    • Remove the bottom cover.
  4. HoMedics TotalComfort UHE-CM18 Fan Replacement: passo 4, immagine 1 di 3 HoMedics TotalComfort UHE-CM18 Fan Replacement: passo 4, immagine 2 di 3 HoMedics TotalComfort UHE-CM18 Fan Replacement: passo 4, immagine 3 di 3
    • Remove the 7 mm screw that secures the metal cover for the fan cable.
    • Remove the metal cover.
  5. HoMedics TotalComfort UHE-CM18 Fan Replacement: passo 5, immagine 1 di 3 HoMedics TotalComfort UHE-CM18 Fan Replacement: passo 5, immagine 2 di 3 HoMedics TotalComfort UHE-CM18 Fan Replacement: passo 5, immagine 3 di 3
    • Disconnect the fan cable from the circuit board by pushing down the center at the end and pulling it out of its socket.
    • Remove the fan.
Conclusione
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 7
Tutti i Tempi: 123
