Introduzione
If the buttons on your humidifier aren't working, follow this guide to access the control panel. This will show a simple step-by-step process of how to remove your control panel for a replacement. For this guide, you will use a Phillips #1 screwdriver head to remove and replace the control panel.
Cosa ti serve
Lift up the water tank and separate it from the humidifier.
Flip the humidifier over to its underside.
Quasi finito!
Conclusione
