Salta al contenuto principale
Hitachi HB-B102 Automatic Home Bakery II Control Panel Replacement
Cosa ti serve
  1. Hitachi HB-B102 Automatic Home Bakery  II Control Panel Replacement, Control Panel: passo 1, immagine 1 di 1
    • Begin by using a # 2 Phillips head screwdriver to remove the two 1.3 cm screws that secure the control panel onto the main body.
  2. Hitachi HB-B102 Automatic Home Bakery  II Control Panel Replacement: passo 2, immagine 1 di 1
    • Now gently pry on the top of the control panel with a metal spudger, it should then pop up.
    • Be careful when it is being removed that you do not damage the tabs that hold the bottom of the panel in place.
  3. Hitachi HB-B102 Automatic Home Bakery  II Control Panel Replacement: passo 3, immagine 1 di 1
    • Now flip the control panel over so that the wire connections are visible.
    • All of the wires are easily removed by grabbing the metal connector and pulling straight out from the panel.
Conclusione
Mike
Membro da: 01/25/17
397 Reputazione
3 Guide realizzate
Cal Poly, Team 9-2, Banghart Winter 2017 Membro di Cal Poly, Team 9-2, Banghart Winter 2017
CPSU-BANGHART-W17S9G2
3 Membri
7 Guide realizzate
1Commento della guida
Where can i buy the power board for hitachi home
bakery HD II -B102 and how much is the price?
janettecrown_66 - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 8
Tutti i Tempi: 549
