Salta al contenuto principale
Hitachi CP-X440 Power Supply Unit Replacement
Cosa ti serve
  1. Hitachi CP-X440 Power Supply Unit Replacement, Motherboard: passo 1, immagine 1 di 1
    • Turn the projector upside down so the bottom is facing up.
    • Remove the 6 black 2 cm screws with a Phillips #1 Screwdriver.
    • The screws are deep in the holes, so be careful when removing them as they can easily fall off the screwdriver tip.
  2. Hitachi CP-X440 Power Supply Unit Replacement: passo 2, immagine 1 di 2 Hitachi CP-X440 Power Supply Unit Replacement: passo 2, immagine 2 di 2
    • Flip the projector right-side up and navigate to the back panel.
    • Remove the 3 black, 1 cm screws on the back panel with a Phillips #1 Screwdriver.
    • Remove the two silver 1 cm screws on the power switch panel with a Phillips #1 Screwdriver.
  3. Hitachi CP-X440 Power Supply Unit Replacement: passo 3, immagine 1 di 2 Hitachi CP-X440 Power Supply Unit Replacement: passo 3, immagine 2 di 2
    • Now turn the projector so the front is facing you.
    • Gently remove the lid from the bottom of the projector so the green circuit board is exposed.
  4. Hitachi CP-X440 Power Supply Unit Replacement: passo 4, immagine 1 di 2 Hitachi CP-X440 Power Supply Unit Replacement: passo 4, immagine 2 di 2
    • Gently remove the cables from their white connectors on the circuit board.
  5. Hitachi CP-X440 Power Supply Unit Replacement: passo 5, immagine 1 di 1
    • Gently pull out the three orange ribbons from their white connectors on the circuit board.
    • You can use a spudger tool to pry them out of place.
  6. Hitachi CP-X440 Power Supply Unit Replacement: passo 6, immagine 1 di 1
    • Remove the 5 silver 0.5 cm screws on the circuit board with a Phillips #2 Screwdriver.
  7. Hitachi CP-X440 Power Supply Unit Replacement: passo 7, immagine 1 di 1
    • Remove the motherboard so the projector is exposed.
  8. Hitachi CP-X440 Power Supply Unit Replacement, Power Supply Unit: passo 8, immagine 1 di 2 Hitachi CP-X440 Power Supply Unit Replacement, Power Supply Unit: passo 8, immagine 2 di 2
    • First remove the sliver plastic protective piece from on top of the power supply unit.
    • Remove the black pin holder by using the spudger.
  9. Hitachi CP-X440 Power Supply Unit Replacement: passo 9, immagine 1 di 3 Hitachi CP-X440 Power Supply Unit Replacement: passo 9, immagine 2 di 3 Hitachi CP-X440 Power Supply Unit Replacement: passo 9, immagine 3 di 3
    • Next unscrew all of the 1 cm screws that are holding the power supply unit to the projector.
  10. Hitachi CP-X440 Power Supply Unit Replacement: passo 10, immagine 1 di 2 Hitachi CP-X440 Power Supply Unit Replacement: passo 10, immagine 2 di 2
    • Next, remove the wires that are attached to the projector from the power supply unit.
  11. Hitachi CP-X440 Power Supply Unit Replacement: passo 11, immagine 1 di 3 Hitachi CP-X440 Power Supply Unit Replacement: passo 11, immagine 2 di 3 Hitachi CP-X440 Power Supply Unit Replacement: passo 11, immagine 3 di 3
    • Remove the black wire by using the Phillips head #2 screw driver to unscrew the 1 cm screw.
    • Once the screw is out, pull on the metal bracket which should come free, and then pull the wire up so it is released.
  12. Hitachi CP-X440 Power Supply Unit Replacement: passo 12, immagine 1 di 3 Hitachi CP-X440 Power Supply Unit Replacement: passo 12, immagine 2 di 3 Hitachi CP-X440 Power Supply Unit Replacement: passo 12, immagine 3 di 3
    • Remove the black wire by using the Phillips head #2 screw driver to unscrew the 1 cm silver screw.
    • Once the screw is out, pull on the metal bracket which should come free. Then pull the wire up so it is released.
    • The third picture marks where the base of the second picture's screw is located.
  13. Hitachi CP-X440 Power Supply Unit Replacement: passo 13, immagine 1 di 1
    • Unscrew the last 1 cm screw to the secondary mother board using the Phillips #2 Screwdriver and the Power supply unit will lift free.
Conclusione
noah wright
Membro da: 03/21/22
133 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 8
Tutti i Tempi: 205
