Cosa ti serve
Turn the projector upside down so the bottom is facing up.
Remove the 6 black 2 cm screws with a Phillips #1 Screwdriver.
As you look at the the device overhead, you will see three pieces of orange ribbon.
Attached to the orange ribbon will be a stabilizer over the lamp.
On each side, unscrew the two 1 cm screws with a Phillips #0 Screwdriver.
Then remove the piece holding the orange ribbons, called the stabilizer from this point on.
