Salta al contenuto principale
Hitachi CP-X440 Air Filter Replacement
Cosa ti serve
  1. Hitachi CP-X440 Air Filter Replacement, Air Filter: passo 1, immagine 1 di 3 Hitachi CP-X440 Air Filter Replacement, Air Filter: passo 1, immagine 2 di 3 Hitachi CP-X440 Air Filter Replacement, Air Filter: passo 1, immagine 3 di 3
    • Begin with turning the projector on its side so the bottom of the device is clearly visible.
  2. Hitachi CP-X440 Air Filter Replacement: passo 2, immagine 1 di 3 Hitachi CP-X440 Air Filter Replacement: passo 2, immagine 2 di 3 Hitachi CP-X440 Air Filter Replacement: passo 2, immagine 3 di 3
    • In the bottom left hand corner of the device there will be a vent.
    • At the bottom of the vent, there will be two pull tabs. Remove the vent by gently pushing up on the tabs.
    • Once the tabs are pushed, the vent will pop out and will be able to easily be taken off the device.
  3. Hitachi CP-X440 Air Filter Replacement: passo 3, immagine 1 di 2 Hitachi CP-X440 Air Filter Replacement: passo 3, immagine 2 di 2
    • Once the vent is removed, you will see the black air filter.
    • To remove the air filter, gently grab the center handle and pull.
    • The air filter can be discarded into a waste basket.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 8
Tutti i Tempi: 207
