Salta al contenuto principale
Hitachi CP-X2511 Battery Replacement
Cosa ti serve
  1. Hitachi CP-X2511 Battery Replacement, Battery: passo 1, immagine 1 di 1
    • First remove the the seven black screws at the bottom of the projector. There should be three on the left side, three on the right side, and one at the very front.
  2. Hitachi CP-X2511 Battery Replacement: passo 2, immagine 1 di 1
    • Step two remove the two stainless steel screws from the back of the device, then gently lift on the outer casing to remove.
  3. Hitachi CP-X2511 Battery Replacement: passo 3, immagine 1 di 1
    • Unscrew the black wire from the mother board (red circle) and unplug the seven cables out of the mother board (orange square).
  4. Hitachi CP-X2511 Battery Replacement: passo 4, immagine 1 di 2 Hitachi CP-X2511 Battery Replacement: passo 4, immagine 2 di 2
    • Now unscrew the nickel screw located by the front of the lens and then the other one by the power cord port.
  5. Hitachi CP-X2511 Battery Replacement: passo 5, immagine 1 di 1
    • Pull the battery and fan out of the projector and replace the whole thing.
Conclusione
Fabian
Membro da: 09/08/23
171 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 4
Tutti i Tempi: 37
