Salta al contenuto principale
Hitachi CP-X2010N Speaker Replacement
Cosa ti serve
  1. Hitachi CP-X2010N Speaker Replacement, Top Panel: passo 1, immagine 1 di 3 Hitachi CP-X2010N Speaker Replacement, Top Panel: passo 1, immagine 2 di 3 Hitachi CP-X2010N Speaker Replacement, Top Panel: passo 1, immagine 3 di 3
    • Flip the projector upside down to expose the screws on the underside.
  2. Hitachi CP-X2010N Speaker Replacement: passo 2, immagine 1 di 3 Hitachi CP-X2010N Speaker Replacement: passo 2, immagine 2 di 3 Hitachi CP-X2010N Speaker Replacement: passo 2, immagine 3 di 3
    • Use a Phillips #2 screwdriver to remove eight black 14 mm screws holding the top panel to the main projector body.
  3. Hitachi CP-X2010N Speaker Replacement: passo 3, immagine 1 di 1
    • Flip projector right side up and orient it so you are facing the rear panel.
  4. Hitachi CP-X2010N Speaker Replacement: passo 4, immagine 1 di 3 Hitachi CP-X2010N Speaker Replacement: passo 4, immagine 2 di 3 Hitachi CP-X2010N Speaker Replacement: passo 4, immagine 3 di 3
    • Use a Phillips #2 screwdriver to remove two silver 22 mm long screws.
    • Use a Phillips #2 screwdriver to remove the short silver 10 mm screw.
  5. Hitachi CP-X2010N Speaker Replacement: passo 5, immagine 1 di 3 Hitachi CP-X2010N Speaker Replacement: passo 5, immagine 2 di 3 Hitachi CP-X2010N Speaker Replacement: passo 5, immagine 3 di 3
    • Carefully lift the top panel from the body of the projector, making sure it doesn't catch on anything.
    • Remove the panel from the body of the projector.
  6. Hitachi CP-X2010N Speaker Replacement, Speaker: passo 6, immagine 1 di 3 Hitachi CP-X2010N Speaker Replacement, Speaker: passo 6, immagine 2 di 3 Hitachi CP-X2010N Speaker Replacement, Speaker: passo 6, immagine 3 di 3
    • Pinch the edges of the two connectors and carefully disconnect both wires from the motherboard.
  7. Hitachi CP-X2010N Speaker Replacement: passo 7, immagine 1 di 3 Hitachi CP-X2010N Speaker Replacement: passo 7, immagine 2 di 3 Hitachi CP-X2010N Speaker Replacement: passo 7, immagine 3 di 3
    • Lightly grab the speakers and pull them up and towards yourself to remove the speakers from the case.
    • For reassembly, pinch the sides of the speakers together to line up middle slot first and then line up outer slots.
Conclusione
Altre 4 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 138
