Salta al contenuto principale
Hitachi CP-X2010N Motherboard Replacement
Cosa ti serve
  1. Hitachi CP-X2010N  Motherboard Replacement, Top Panel: passo 1, immagine 1 di 3 Hitachi CP-X2010N  Motherboard Replacement, Top Panel: passo 1, immagine 2 di 3 Hitachi CP-X2010N  Motherboard Replacement, Top Panel: passo 1, immagine 3 di 3
    • Flip the projector upside down to expose the screws on the underside.
  2. Hitachi CP-X2010N  Motherboard Replacement: passo 2, immagine 1 di 3 Hitachi CP-X2010N  Motherboard Replacement: passo 2, immagine 2 di 3 Hitachi CP-X2010N  Motherboard Replacement: passo 2, immagine 3 di 3
    • Use a Phillips #2 screwdriver to remove eight black 14 mm screws holding the top panel to the main projector body.
  3. Hitachi CP-X2010N  Motherboard Replacement: passo 3, immagine 1 di 1
    • Flip projector right side up and orient it so you are facing the rear panel.
  4. Hitachi CP-X2010N  Motherboard Replacement: passo 4, immagine 1 di 3 Hitachi CP-X2010N  Motherboard Replacement: passo 4, immagine 2 di 3 Hitachi CP-X2010N  Motherboard Replacement: passo 4, immagine 3 di 3
    • Use a Phillips #2 screwdriver to remove two silver 22 mm long screws.
    • Use a Phillips #2 screwdriver to remove the short silver 10 mm screw.
  5. Hitachi CP-X2010N  Motherboard Replacement: passo 5, immagine 1 di 3 Hitachi CP-X2010N  Motherboard Replacement: passo 5, immagine 2 di 3 Hitachi CP-X2010N  Motherboard Replacement: passo 5, immagine 3 di 3
    • Carefully lift the top panel from the body of the projector, making sure it doesn't catch on anything.
    • Remove the panel from the body of the projector.
  6. Hitachi CP-X2010N  Motherboard Replacement, Motherboard: passo 6, immagine 1 di 3 Hitachi CP-X2010N  Motherboard Replacement, Motherboard: passo 6, immagine 2 di 3 Hitachi CP-X2010N  Motherboard Replacement, Motherboard: passo 6, immagine 3 di 3
    • Carefully pinch the edges of the two blue connectors and pull upwards to remove them from the motherboard.
    • Carefully pinch and remove the small gray connector next to the blue wire opposite the speakers.
  7. Hitachi CP-X2010N  Motherboard Replacement: passo 7, immagine 1 di 3 Hitachi CP-X2010N  Motherboard Replacement: passo 7, immagine 2 di 3 Hitachi CP-X2010N  Motherboard Replacement: passo 7, immagine 3 di 3
    • Use a Phillips #2 screwdriver to remove the two black 14 mm screws securing the button array.
    • Move the wires for better access to the screws if needed.
  8. Hitachi CP-X2010N  Motherboard Replacement: passo 8, immagine 1 di 3 Hitachi CP-X2010N  Motherboard Replacement: passo 8, immagine 2 di 3 Hitachi CP-X2010N  Motherboard Replacement: passo 8, immagine 3 di 3
    • Remove the bracket that was being held by the screw.
    • Take a picture or memorize its orientation for easier reinstallation.
  9. Hitachi CP-X2010N  Motherboard Replacement: passo 9, immagine 1 di 2 Hitachi CP-X2010N  Motherboard Replacement: passo 9, immagine 2 di 2
    • Pull the button array and network adapter out carefully.
    • Make sure all the wires connected to the array are unplugged.
  10. Hitachi CP-X2010N  Motherboard Replacement: passo 10, immagine 1 di 2 Hitachi CP-X2010N  Motherboard Replacement: passo 10, immagine 2 di 2
    • Use a Phillips #2 screwdriver to remove the silver 10 mm screw securing the ground wire.
    • Keep the screw and washer in an easily accessible place.
  11. Hitachi CP-X2010N  Motherboard Replacement: passo 11, immagine 1 di 1
    • Use a Phillips #2 screwdriver to remove the black 14 mm screw securing the motherboard to the case.
  12. Hitachi CP-X2010N  Motherboard Replacement: passo 12, immagine 1 di 3 Hitachi CP-X2010N  Motherboard Replacement: passo 12, immagine 2 di 3 Hitachi CP-X2010N  Motherboard Replacement: passo 12, immagine 3 di 3
    • Delicately pinch and pull off all the wired connections surrounding the outside of the motherboard.
  13. Hitachi CP-X2010N  Motherboard Replacement: passo 13, immagine 1 di 3 Hitachi CP-X2010N  Motherboard Replacement: passo 13, immagine 2 di 3 Hitachi CP-X2010N  Motherboard Replacement: passo 13, immagine 3 di 3
    • Use the tip of a spudger or your fingernail to flip up the small locking flap on the three orange cable locks. Then, you can safely pull the cables out.
    • Too much force could break the ribbon cable.
  14. Hitachi CP-X2010N  Motherboard Replacement: passo 14, immagine 1 di 2 Hitachi CP-X2010N  Motherboard Replacement: passo 14, immagine 2 di 2
    • Lift the motherboard out from the projector carefully so that it doesn't catch on any other components.
Conclusione
Altre 4 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 7
Tutti i Tempi: 234
