Salta al contenuto principale
Hipstreet Titan Plus Screen Replacement
Cosa ti serve
  1. Hipstreet Titan Plus Screen Replacement, Screen: passo 1, immagine 1 di 2 Hipstreet Titan Plus Screen Replacement, Screen: passo 1, immagine 2 di 2
    • Use the iFixit opening tools to pry the screen from the back casing of the device.
    • Now that the screen and back casing have been separated, lay them flat on the table with the inside facing up.
  2. Hipstreet Titan Plus Screen Replacement: passo 2, immagine 1 di 1
    • Use the spudger tool to remove the speaker from back casing of the device.
  3. Hipstreet Titan Plus Screen Replacement: passo 3, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Use the tweezers to remove the black adhesive strips covering the wires.
    • After, set the strips aside. You will use them later.
  4. Hipstreet Titan Plus Screen Replacement: passo 4, immagine 1 di 2 Hipstreet Titan Plus Screen Replacement: passo 4, immagine 2 di 2
    • Use the spudger to release the three black clips.
    • Ensure to remove the main far right clip, which connects the screen to the motherboard.
  5. Hipstreet Titan Plus Screen Replacement: passo 5, immagine 1 di 2 Hipstreet Titan Plus Screen Replacement: passo 5, immagine 2 di 2
    • Remove the three screws from the bottom of the motherboard.
  6. Hipstreet Titan Plus Screen Replacement: passo 6, immagine 1 di 2 Hipstreet Titan Plus Screen Replacement: passo 6, immagine 2 di 2
    • Use a spudger to gently remove the battery from the motherboard.
  7. Hipstreet Titan Plus Screen Replacement: passo 7, immagine 1 di 1
    • All components will be removable from the screen after the battery, motherboard and all the black clips have been undone.
  8. Hipstreet Titan Plus Screen Replacement: passo 8, immagine 1 di 2 Hipstreet Titan Plus Screen Replacement: passo 8, immagine 2 di 2
    • Use the spudger to push back the clips along the side of the device and remove the screen.
Conclusione
Altre 2 persone hanno completato questa guida.
Kari Cannon
Membro da: 10/30/15
500 Reputazione
4 Guide realizzate
UMass Dartmouth, Team 1-1, Miles Fall 2015 Membro di UMass Dartmouth, Team 1-1, Miles Fall 2015
UMASSD-MILES-F15S1G1
3 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 10
Tutti i Tempi: 529
